It is currently Tue Jul 15, 2025 1:31 am
 Post subject: Seat Pin Removal
PostPosted: Thu Apr 20, 2006 10:17 am
Gday All
i just recently got my clubby some better low back clubman seats but they came with out the pins that hold the base to the back. so i will have to salvage the ones.
is there anyway to remove these without wrecking them? any hints are most appreciated
PostPosted: Thu Apr 20, 2006 6:54 pm
come on surely someone knows :shock:
 Post subject: Ummmmmm???
PostPosted: Thu Apr 20, 2006 7:11 pm
Mr Angle Grinder :?: :roll:
PostPosted: Thu Apr 20, 2006 7:15 pm
i want to "SALVAGE" them so any other suggestions :lol:
PostPosted: Thu Apr 20, 2006 7:58 pm
hmmmm...... I took mine out when my seats were retrimmed last year.
I can't remember exactly HOW, but I don't reacall having ANY problems.
I have high back Clubman seats.
Website: www.justanothermini.com
PostPosted: Thu Apr 20, 2006 8:12 pm
angle grinder and then replace with nut and bolt
PostPosted: Thu Apr 20, 2006 8:39 pm
will see how i go
PostPosted: Thu Apr 20, 2006 8:59 pm
Well the ones I have stripped down have been no problem as the pin has had a circlip on the inside and once removed ,the rest is a piece of cake. IF you have to cut the pins, then I may still have a few with clips lying around if you end up needing some.
David
PostPosted: Thu Apr 20, 2006 9:19 pm
yep, thats it! a circlip.
maybe the earlier Clubby seats are different and don't have that?
PostPosted: Thu Apr 20, 2006 9:23 pm
yeah these have a little clip, hopefully i wont need to cut them but if do i might have to PM you, DWASmith if icant source some locally :wink:
Users browsing this forum: Bing [Bot] and 95 guests
