It is currently Sat Jul 12, 2025 9:01 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Apr 20, 2006 10:38 pm
Stuwey_LS wrote:
Why the A+ Head on the 'S' block :?
Be careful with that heatwrap - it can keep too much the tubing, making it weak - and crack. And deform in other places. I never believed it until it happened to me :(
Nah, she's a standard A series 12G940 head (With the S valves of course), never had any reason to think otherwise. Why do you think it's an A+? Unless you are comparing it to a MK1 head with the different intake and exhaust face? Or the heavily sculpted top surface of the turbo head? (The thermostat end is machined flat like normal 940's)
Yeah I have heard that about the wrap before, were you able to then weld it up again? or had the steel been to far gone? I've kept mine a bit wrapeed once over so as not to insulate it to the Nth degree, I hope that helps. I had it wrapped on a stainless steel WRX system for 4 years, it used to run up and down the no speed limit Northern Territory Highways for all that time with no probs, but it was stainless after all.
PostPosted: Thu Apr 20, 2006 11:01 pm
I was just looking at the casting shape on the end of the head - and no heater take-off :?:
My exhaust was GONE. One set of Maniflow LCB's in the bin :( Where the wrap was pulled tight, it had squished the pipes. Where it was heavily overlaid or there were some tighter bends in the pipe, it was really quite bad. The pattern off the fibreglass was imprinted into the pipes! The weld where 1&3 join usually cracks, too. My brothers' ones did that when wrapped. But they were Wildcats.
I only used it to get some heat away from the weber. Now i won't run the tape. I'm sure i'll end up making some form of heat shield one day.
PostPosted: Thu Apr 20, 2006 11:18 pm
2.5" mandrel bent exhaust and dump into a Lukey straight thru muffler with 2" tips.
Matt
PostPosted: Fri Apr 21, 2006 8:25 am
Nah, pretty sure sh'e just an A series head. The heater take off is just covered up because it's just been painted. Also there's only one stud fitted for the hater take off which may throw you off.
 Post subject: 1071's 1330 Engine...
PostPosted: Fri Apr 21, 2006 5:26 pm
[Posted for Ian who obviously has problems understanding computer programs :P ]
PostPosted: Fri Apr 21, 2006 6:18 pm
pretty crap pic but only one i have at the moment.. sounds good so thats all that matters :)
GTi Turbo'd mini, abused daily
PostPosted: Fri Apr 21, 2006 8:52 pm
For those that have cannons fitted do you have troubles with speed bumps and potholes ?
PostPosted: Fri Apr 21, 2006 8:57 pm
On a lowered car YES.
On a normal height car NOT usually, unless it droops excessively.
PostPosted: Fri Apr 21, 2006 8:58 pm
we've all been there :lol: :lol: :lol:
well thats my exhaust, it is now welded on at the back and it bows in the middle, fun on speed bumps and goinig into the garage.
PostPosted: Fri Apr 21, 2006 9:03 pm
bit shadowed out there sorry :wink:
Potato
PostPosted: Fri Apr 21, 2006 9:20 pm
I did.
But like willy said, lowered cars have issues....and mine was lowered because the cones were shot.....not by choice.
No more Minis!......For now.
PostPosted: Fri Apr 21, 2006 10:00 pm
i like meenis, i want to put a canon on the clubby, but the zorst sits pretty low atm :? and i think the cones r shot, the wheels hit lots, dont have much flair left!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Apr 21, 2006 11:46 pm
Here's one for you can you find it?
PostPosted: Sat Apr 22, 2006 12:18 am
minstar is that a fuel line? and a fuel pump?
heat shielded right?
PostPosted: Sat Apr 22, 2006 10:35 pm
nothing to fancy but heres mine
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
Users browsing this forum: Phil 850 and 90 guests
