It is currently Wed Jul 23, 2025 11:35 am
 Post subject: getting it started
PostPosted: Sat Apr 22, 2006 1:58 pm
so, the engine is in and everything is connected up - all ready to go, with the wiring all worked out too :D
trying to get it started today, it cranks, fuel is pumping into the carby, have spark to all 4 plugs - but no start.
what should i check and do? cheers
PostPosted: Sat Apr 22, 2006 2:10 pm
adjust your timing, and or the placement of the leads on the plugs
ie: swap 1 with 3 or 2 with 4
PostPosted: Sat Apr 22, 2006 2:52 pm
how do i adjust my timing :?
PostPosted: Sat Apr 22, 2006 2:59 pm
try the leads first then,
you turn the dizzy clockwise/anti clockwise, there is a bracket that holds the dizzy in place, slacken it off so you can turn it by hand.
clockwise is advance, anti clockwise retard, just try it about the place till it fires, then adjust it till it revs nicely
you should then get it tuned properly, it shouldnt take more than 30 mins which = about $30
PostPosted: Sat Apr 22, 2006 3:22 pm
it just doesnt sound like it even wants to start though :? im pretty sure the leads are in the correct position. number 1 at about 4 o clock, number 3 at about 1 o clock then 4, then 2.
so ur saying my moving the distributor forward or backward it could do the trick :?
PostPosted: Sat Apr 22, 2006 3:49 pm
swap the leads and see if that fixes it before you mess with the tuning :wink
1 with 3 and 2 with 4
PostPosted: Sat Apr 22, 2006 5:08 pm
still nothing :x
dont know what to do now... :?
PostPosted: Sat Apr 22, 2006 5:28 pm
Spaceboy what were you thinking ????????????? its 1 with 4 2 with 3 not what you wrote and I hope Aussie didn't follow those instructions :lol:
Jon
PostPosted: Sat Apr 22, 2006 5:38 pm
Jon
I did follow thos instructions :shock:
PostPosted: Sat Apr 22, 2006 7:15 pm
I would have thought that number 1 would be at 1 o'clock.You're not 90 degrees out are you ?
PostPosted: Sat Apr 22, 2006 7:18 pm
then reverse what you did :D
Jon
PostPosted: Sun Apr 23, 2006 11:19 am
it was a combination of a few things..carby was blocked also, but yea got it started thismorning with some help from whodat last night! cheers :D
PostPosted: Sun Apr 23, 2006 12:37 pm
new problem...
now when i start it up it gradually increases the rev's then it revs really high then higher, then dies down again - and keeps doing this.
i replaced the fuel filter and that hasnt helped. what should i do?
PostPosted: Sun Apr 23, 2006 1:05 pm
check to see if your fuel pump is pumping correctly and all the linkages on the carby are not sticking.
PostPosted: Sun Apr 23, 2006 7:12 pm
I had the same problem ages ago when I used the old carbies, check all your linkages and make sure everything is clean. I bought some of that carby and throttle body cleaner, but some degreaser will work just as well, that worked for me. Could be your choke cable getting caught on something?
Mini Clubman, 1.3i, air con, 12" mags, pioneer sound system.
Users browsing this forum: kirby and 92 guests
