It is currently Thu Aug 14, 2025 6:48 pm
 Post subject: problems in da engine...
PostPosted: Tue Apr 25, 2006 1:39 pm
help! i checked my oil today and i've got a white/brown coloured oil in my head :( my question is...whats gone wrong?
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Tue Apr 25, 2006 1:51 pm
water in the oil most likely a head gasket gone. :cry:
68 Mini
70 Moke
PostPosted: Tue Apr 25, 2006 1:55 pm
yep sounds like the head gasket to me. bad luck
PostPosted: Tue Apr 25, 2006 1:59 pm
what is the colour of the oil in the sump? if it black/brown and not the milky off white colour then the next time when the car is hot drop oil from the dipstick on to the manifold if it just smokes then it has no water in it or if it sizzles and boils then you can tell if there is any water in there.
the condensation in the head indicates a blown head gasket as smarty and stef have already pointed out.
head gaskets are relatively cheap but it is a fairly big job. get your hands on a workshop manual if you dont already have one and see if you have the tools to do it
remember to torque the head correctly after
i have a work shop manual in electronic form so PM me if you would like it :wink:
best of luck with the repairs
PostPosted: Tue Apr 25, 2006 2:00 pm
Check the dipstick- if oil looks milky, dump it and the filter before you run it again after fixing head.
<edit> best head gasket these days is the ACL one. Available from Repco, AutoBarn, etc.
make sure the block and head are dead clean before fitting.
PostPosted: Tue Apr 25, 2006 3:41 pm
alrighty then....well the dipstick is just black oil
and the head has returned to black after me filling up the car with oil again
on sunday i went to gundagai and its been a little while since my last oil change could this just be old oil?
I smile everytime!
PostPosted: Tue Apr 25, 2006 3:50 pm
what brand oil do you use ?? I have experienced some oils that have this effect on mini motors especially in cold weather. May look like a blown head gasket but just normal condensation sitting in oil cap. If it is a head gasket you will be using coolant is it using coolant ??
PostPosted: Tue Apr 25, 2006 3:55 pm
also check if there is oil in your radiator or bubbles in your radiator
PostPosted: Tue Apr 25, 2006 4:17 pm
i use Castrol Edge Sport (25-30 W) (Its the replacement for the old Formula R Black)
Nope not using coolant, and nope no oil in the coolant or bubbles.
Car seems to be working fine as well nothing out of the norm.
I smile everytime!
PostPosted: Tue Apr 25, 2006 4:53 pm
Probably what you are seeing then is called `mayo', condensation caused by cold weather and short running.
Moisture byproducts of combustion condense on the cold metal of the rocker cover etc, and combine with the oil film there.
If it goes away with a decent run, it's nothing. :wink:
PostPosted: Tue Apr 25, 2006 5:08 pm
fantastic news! thankyou all! :D
had me scared there for a while
I smile everytime!
PostPosted: Tue Apr 25, 2006 5:55 pm
Yes I agree with the Doc, it is just mayo from condensation.
I can't believe all the people saying it was a head gasket. :roll:
Here we are just into the cold months, it is prime time for mayo to be formed in the rocker cover. I could go out to my Morris now and probably find it under my oil cap. :wink: A long drive will burn it away.
PostPosted: Tue Apr 25, 2006 7:14 pm
Rule of thumb... :wink:
1.0L of fuel burned produces ~1.5L of water vapour, some of which is bound to get past the rings. Add cold engine parts for it to condense on, and you can see why it happens.
<edit> Hey if your oil is BLACK as you said, it's time for a change.. Do the filter, too... :wink:
PostPosted: Tue Apr 25, 2006 7:17 pm
its always black about 50 miles in....is this a problem?
I smile everytime!
PostPosted: Tue Apr 25, 2006 7:25 pm
Either the motor is worn and has lots of blowby past the rings, or it's been allowed to sludge up in the past and the clean oil hasn't got it all out yet.
Do a few oil changes at 500 mile intervals with el cheapo 20W/50, see if that helps. :wink:
Users browsing this forum: No registered users and 193 guests
