It is currently Tue Aug 12, 2025 11:44 am
 Post subject: moke bits
PostPosted: Tue Apr 25, 2006 5:01 pm
hello all
just wondering what bits i can use off a moke on my clubman?
engine& box brakes etc ???
PostPosted: Tue Apr 25, 2006 5:13 pm
yeah, yopu can use nearly all the mechanicals except for the differential & the rear trailing arms & wheels etc
all the rest is usefull for mini swap
PostPosted: Tue Apr 25, 2006 5:17 pm
so if it has a disc setup i can use it
cheers darrin
PostPosted: Tue Apr 25, 2006 5:21 pm
cheers darrin
Yes but you'll need to use 12 or 13" wheels unless you are lucky enough to find a moke that someone has put cooper S 7 1/2" discs onto , mokes used the larger 8.4" discs .
PostPosted: Tue Apr 25, 2006 5:31 pm
thanks miniman & sports 850
i think fitting 12's or 13's may be a small price to pay for the disc brake setup
also if it is an original californian it should have a 1275 ... am i right?
Darrin
PostPosted: Tue Apr 25, 2006 5:44 pm
probably a 50/50 type deal , Californians also came out with a 998 and looked almost the same as the 1275 one . You'd still have a pretty good chance of it being a 1275 though , especially if it's got disc brakes as the 998 only had drums from memory .
PostPosted: Tue Apr 25, 2006 5:55 pm
A moke must be pretty bad to scavange it for parts for a clubbie. How bad is it?
You might be better off peddling it on ebay and buying new parts for you clubbie.
PostPosted: Tue Apr 25, 2006 5:56 pm
Moke bits are getting difficult to find.
If the Moke you are wrecking for mechanical bits is rusted beyond help, you can always sell off the rest. eg: Bumpers, rear trailing arms, wheels, factory rollbars and windscreen frames.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Apr 25, 2006 7:27 pm
I am just toying with the idea as i was told of a moke for sale at the right price i am trying to get in contact with the friend of the owner to get his number to find out more details .. apparently the car has seen better days but i am yet to know for sure ...
i figured if its bad i could parts it or if not resell it
PostPosted: Tue Apr 25, 2006 9:28 pm
let me know if you want to resell it ;)
Users browsing this forum: Sharri29 and 273 guests
