It is currently Thu Jul 17, 2025 3:31 am
 Post subject: Window washer jets
PostPosted: Fri Oct 08, 2004 10:21 am
Is it possible (ie. easy :wink: ) to swap over the old squirt squirt washer thing from a Morris with an electric no longer impotent washer from a Clubbie...?
I havent seen a Clubbie washer close up enough to tell. :oops:
PostPosted: Fri Oct 08, 2004 12:12 pm
I've got a Toyota one in my roundnose- holds more water than the Clubbie one, it's bolted under my LF guard.
Push button switch is wher the manual button was. Works great! 8)
PostPosted: Fri Oct 08, 2004 3:25 pm
I bort a kit that supercheap sells for my Van. Real easy to fit. Put the button where the pump thinga is now. Wire it up. I mounted the bottle on the inner guard above the clutch.
PostPosted: Fri Oct 08, 2004 10:28 pm
lol...I was at Pick and Paymore today, pocketing Honda Civic washer jets. They are pretty cool and will slot into the hole that a Clubby has. Much better than BMC / Leyland items :wink:
