It is currently Tue Aug 05, 2025 4:09 pm
 Post subject: hinge and door questions
PostPosted: Wed Apr 26, 2006 11:18 pm
so the mini finally got painted this week..
so its time to start putting it back together..
but, with putting the doors on.. is there anything u can put between the hinges and the door? to kinda prevent rusting?
do i buy these things? make them out of something?
any help is good
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Thu Apr 27, 2006 2:28 am
These..:
http://cgi.ebay.com.au/Door-Hinge-Gaskets-Mini-Complete-Set-Prevent-Rust_W0QQitemZ4633925586QQcategoryZ32072QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Don't know what the going rate is, you can probably find them cheaper elsewhere, but that's what you want :)
PostPosted: Thu Apr 27, 2006 6:43 am
There are 2 sorts of gasket-
One is a flat type made from gasket material, (from Karcraft)
Other is a moulded rubber one (I got from MG Heritage).
Not sure which is the Kosher one, I think the 1st type.
PostPosted: Thu Apr 27, 2006 6:46 am
Interesting, i guess the flat one you can't see?
Did they have any from the factory? They wouldn't of had the rubber one as you can visibly see that and i've never seen it in any promo shots or on any restored or original cars..
Surely they put something there? ie. the flat gasket material?
PostPosted: Thu Apr 27, 2006 6:51 am
I'm pretty sure it was just flat gasket-like material. But after 30+ years they are never intact.
The original hinges are actually cast iron, surprise surprise.. I know this `coz I've repinned and bushed some.
PostPosted: Thu Apr 27, 2006 12:12 pm
the rubber ones are the ones i have seen and am thinking of getting.. do you know the going rate for them??
never late in a 998
PostPosted: Thu Apr 27, 2006 12:50 pm
I paid $2/gasket for the flat ones. Total =$16, pretty sure the rubber ones are dearer.
PostPosted: Thu Apr 27, 2006 3:14 pm
:shock: My doors went on without gaskets.
Should I take them off again. I painted the car with the doors on though so it could get messy. Argh. Why didn't I know this.
PostPosted: Thu Apr 27, 2006 4:33 pm
1. i think cars should be painted with hinges off (infact, everything off including seam covers)
2. rubber gaskets should be fitted... you risk too much with the thins
Inconspicuously Conspicuous
 Post subject: Lip
PostPosted: Thu Apr 27, 2006 5:55 pm
I would never give the Doc lip...but...AFAIR....the early deluxe hinges had the rubber/neoprene affair with the lip around it.
PostPosted: Thu Apr 27, 2006 7:08 pm
You might be right Mick, I canna remember what my `61 850 had, but my 70 `matic had remnants of the flat ones inside.. :wink:
PostPosted: Thu Apr 27, 2006 10:22 pm
The body and add ons (doors bonnet and boot) were originally painted separately then assembled with gasket paper type gaskets under the hinges (similar to those now available from various suppliers). They then had a final finish coat applied
When the Rota Dip process was discontinued in the early seventies the cars were assembled from panels with cathodic coating (also using gasket paper type gaskets) then painted using an electostatic process which was supposed to coat the whole car. As seen by the rust under the hinges on most clubmans the end result wasnt very succesfull
The rubber type gaskets are aftermarket and dont attract moisture so tend to minimise the rust problem
 Post subject: Gold
PostPosted: Sat Apr 29, 2006 9:03 am
Thats gold Ken....this advice should be a stickey on Ausmini....so...does anyone know if you can get the neoprene/rubber/aftermarket/lipped gasket thingys in Oz :?:
PostPosted: Sat Apr 29, 2006 11:21 am
Yes, I bought a set from Heritage MG at Smithfield.
www.mgspareparts.com.au
yes they sell Mini Parts too... :wink:
 Post subject: 1967
PostPosted: Sat Apr 29, 2006 12:41 pm
Hmmmm it came back to me in a blinding light....I think I can now remember fitting the after market rubbers to my first car (Deluxe)....and helping some others do the same. Think I got em from a little parts shop on Illawarra Road in Marrickville....does that suburb still exist :lol:
Thanks Doc...I'm on it :)
