hello all!
im having radiator troubles at the moment, its pretty bad as when i pour the water in, it pours straight out, and i am overheating within about 10 minutes. so i got a "new" radiator (amongst other parts) and i was going to put in in this morning. i flushed it out both ways, and i noticed that the top radiator hose comes out the front, not the back like my current one.
Question one: is it possible to turn the thermostat housing around to accomodate the new direction of the top hose? it is the one with the holes to screw in the anti pollution gear (which i dont have). if it is possible i will need new gaskets right?
so i went out to my car and i'm looking at the engine, and i notice the plumbing for my heater (which doesnt work) it comes out of the block or head (can't remeber which) and a rubber pipe goes through the bulkhead/firewall to my heater, then back up and connects to a small pipe going doen the front of the radiator.
Question two: the new rad doesnt have this pipe. can i fit it? how will i bypass the heater and plumb the brass elbow by cyl. 4 back to the rad?
cheers fellas, ill be in touch soon!
