It is currently Sat Jun 28, 2025 7:20 am
 Post subject: Automatic MG Metro Turbo
PostPosted: Wed May 10, 2006 2:38 pm
Hi guys
I just starting to look into converting my 1968 MG 1100's engine to an MG metro turbo. I was wondering if anyone could tell me if they made these in automatic? I have searched a bit and can't find whether they were made or not. If anyone knows please let me know :D
Cheers!
PostPosted: Wed May 10, 2006 3:44 pm
I don't know for sure whether they were, but i doubt it. I don't see any reason why you just couldn't slap it onto an auto box?
PostPosted: Thu May 11, 2006 6:52 am
Hi i don't think it has been done, but it would probably change gear before the turbo kicked in.
my swiftmini @ http://www.16vminiclub.com/forums/viewtopic.php?t=4888Image
PostPosted: Thu May 11, 2006 8:22 am
You'd have to get an Auto block, or possibly modify the manual block. Transfer all the metro gear over. No reason why it can't work.
You can adjust when the auto changes gear, so that wouldn't be a problem.
PostPosted: Thu May 11, 2006 8:23 am
Swiftmini
You can change the setting on the auto boxes to tell it when to change gear...
Baracade
PostPosted: Thu May 11, 2006 12:19 pm
No, they never made them in Auto with Turbo.
Much as I am a fan of the Auto, I'm not sure it could cope with the torque. The manual gearboxes couldn't stand the punishment very long. But would be an interesting project. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu May 11, 2006 12:20 pm
yes the shift point is adjustable but only a little, i have found that there is about 2000rpm difference from one to the other, about 3000rpm on lowest to 5000rpm highest. You can rev it as hard as you want when gear is selected and not in drive.
1974 Moke - 998cc
PostPosted: Mon May 22, 2006 7:27 pm
If you put a stronger spring in the kickdown mechanism it will raise the shift points.
Users browsing this forum: No registered users and 23 guests
