It is currently Sat Jul 12, 2025 8:48 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
Which engine type?
Nuts NA Motor 69%  69%  [ 11 ]
Forced Induction 13%  13%  [ 2 ]
Injected Mini Engine(NA) 19%  19%  [ 3 ]
Total votes : 16
PostPosted: Sun Apr 11, 2004 10:23 pm
Turbo and injection won't mix on a Mini, unless you run SPI, and even then it would be a PITA....
No way can you get decent fuel distribution with MPI (2 injectors) and siamese intake ports- the cylinders charge rob each other. Many have tried to map these things properly on an A series, including KC, and chicm on MM/MS board, they can't even get high power and smooth running from MPI without a turbo..
If you MUST run turbo on an A series, I'd stay with the metro Turbo carb.. it works, even on James's 998 turbo.. :wink:
PostPosted: Sun Apr 11, 2004 11:35 pm
thats the setup im using.......much easier than stuffing around with other gear
[Maverick] 1971 Mini K
Users browsing this forum: Bing [Bot] and 90 guests
