It is currently Wed Aug 13, 2025 11:59 am
 Post subject: Clubman Flares
PostPosted: Thu May 11, 2006 12:33 pm
I've got to replace the flares on my Sunshine project cars as the aftermarket fiberglass ones are mostly busted.
Does anyone have any tips on flares that will fit the clubman as well as fit over the S metal guard extensions fitted for the original flares? I'll be using 4.5 inch or 5 inch wide wheels once the car is back on the road.
Mick
PostPosted: Fri May 12, 2006 3:20 pm
Anyone?
Bueller,.....bueller.......bueller.......bueller...
PostPosted: Fri May 12, 2006 3:43 pm
use the replacement which i think is plastic, but identical
i think they're $45 a corner
or you can get the "innocenti" type flares which were also used on the late model rover non sportspack minis, these are plastic screw on type, and are cheap
PostPosted: Fri May 12, 2006 4:55 pm
Standard clubman flairs! 8)
PostPosted: Fri May 12, 2006 6:39 pm
Yeah I do like the standard clubman flares, but they're not really exciting.....
Users browsing this forum: Barkfast and 271 guests
