It is currently Sun Jul 27, 2025 4:13 pm
PostPosted: Sat May 13, 2006 9:13 am
hi, just wondering if anyone new what minis had as a base primer originally underneath? i've stripped all the tar crap off the bottom and theres a light brownygreen coat of paint on there. is it enamel based? can i just primer over this or does it have to be all stripped back to metal? i don't want to use acrylic primer over it just for it to react and come off.
 Post subject: base under coat
PostPosted: Sat May 13, 2006 10:55 pm
on the old minis it was a red coloured enamel undercoat(used to be known as red oxide)
so if you can top coat should be enamel as well for originallity but it chips and may blister later on
if you want a great job go back to bare metal and use the latest paint technology
you wont be sorry -- give your pride and joy 13 coats huh :lol:
PostPosted: Sun May 14, 2006 9:17 pm
13 coats? I'm going to buy shares in your paint distributor. :D
Take it easy, & if it's easy take it twice!!
PostPosted: Mon May 15, 2006 8:55 am
i'd say take it all back and then spray it with "etch primer", not just normal primer. etch primer contains an acid which actually digs into the metal and protects it as opposed to normal primer which just sits ontop.
normal primer is fine for a quick touch up of a rusty spot but if you planning for a full respray go for etch primer
