It is currently Sun Jun 22, 2025 12:40 pm
 Post subject: Front Wheel Bearing Help
PostPosted: Wed May 17, 2006 11:22 am
Hi All
I have done extensive searching of the archives on this but remain slightly uncertain. Am I right in thinking that if I have a 76 Clubby (which I do) I can replace the old bearings with Timken tapered roller bearings with no modifcations required. I just need to get a kit, making sure it has a spacer in it and away I go.
P/no per previous Doc post for the kit with spacer is LM67049A-9F2B8
I think only one side needs doing, getting a rumbling when running above about 40kph which seems to be a knock for every rotation of the wheel, (although I will probably do both, but maybe the second a wekk or two later). Presumably one side only can be done without drama.
Rick
PostPosted: Wed May 17, 2006 11:31 am
Yes, you are right. They fit right in and you would be better off doing both side at the same time.
Pete
 Post subject: Wheel Bearings
PostPosted: Wed May 17, 2006 2:04 pm
Hi Yep they fit straight in, i just changed both front one's as they knocked it back on a blue slip. easy as. :lol:
