It is currently Sat Jun 21, 2025 12:40 am
 Post subject: Suspension
PostPosted: Wed May 17, 2006 2:09 pm
Hi all just after some help on my 1977 clubby. It seems to be leaning to one side the drivers side is higher than the passenger side it has rubber cone suspension.
Thanks :?
PostPosted: Wed May 17, 2006 2:55 pm
jack it up and have a look at the top arm on the dropped side, possibly a knuckle joint or the alloy cone is broken..
PostPosted: Thu May 18, 2006 10:36 am
Hi thanks has the rear and front both got alloy cone's.
It leans front and rear.
Thanks again.
:D
PostPosted: Thu May 18, 2006 11:31 am
Yep, there is an Allot trumpet that sits between the rubber cone (or hi-lo's instead if someone has fitted them)
Are you sure it's a rubber car? cause if a whole side has dropped that's usually a hydro trait, just needs pumping up if the bags are still good.
The trumpet looks like this:
Users browsing this forum: Bing [Bot] and 83 guests
