It is currently Sat Jun 21, 2025 11:01 am
PostPosted: Mon May 15, 2006 8:47 pm
I have just pull a 1380 down for a re-ring and bearings and unsure what these rods are from. They are have 1.625 journals but the part number AEG521 does not show up in any of my parts books. And the numbers on the end caps have been machined off.
And also why would the end caps have be machined like this?
Thanks Pete
PostPosted: Mon May 15, 2006 8:51 pm
1275 Cooper S dude.
Rods are like that because they have been balanced.
Some S rod caps had a recess machined in there, some like yours did not.
I have a set of each... :wink:
PostPosted: Mon May 15, 2006 8:55 pm
Thanks Doc, those numbers are different in the book I have. Will have to add them to the list.
Pete
Part number AEG520 shows up as the early 1100S rod.
BMC sometimes has casting numbers one digit out from the part number, an example being the famous 648 cam with 649 stamped onto it.
PostPosted: Mon May 15, 2006 9:06 pm
Early 1100S rod and Cooper S were same really, I have a set of each and both are marked 521.
Not to be confused with the later 1100S ones (for 1.75" crankpin) with the dirty big lumps on them...
PostPosted: Tue May 16, 2006 1:14 pm
Yep 1275 Cooper 'S'
177, early 1275 Cooper 'S'
521, 1275 Cooper 'S' and some 1100S
625, 1275 Sprite, Midget and some 1100S
Then came the large journal rods.......
PostPosted: Tue May 16, 2006 7:20 pm
Yes, the ones shown are in fact early 1100"S" type (small jhournal) & are essentially the same part & part # as cooper"S" but without the "Factory balancing" that the "S"`s got
rod caps are AEG145 i believe
easy-peasy
PostPosted: Wed May 17, 2006 8:34 am
easy-peasy
Yeh, can just make out the numbers on one of the rod caps and it is AEG145.
Pete
PostPosted: Wed May 17, 2006 5:38 pm
It`s pretty cool really cause the later rods (521s) have the very same cap(145)
but don`t swap them over, allways keep the same cap with the same rod!!!!!!!!!!!
easy-peasy
Users browsing this forum: acarseldine and 91 guests
