It is currently Sat Jul 19, 2025 11:13 am
 Post subject: ROH Contessa rims 10x?.?
PostPosted: Fri May 19, 2006 3:08 pm
Ok, question did the ROH Contesta/Contessa rims come in different widths?
eg. 10x5, 10x5.5
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Fri May 19, 2006 3:33 pm
Not sure about the width, but they did come in different offsets...an LS version and what i would say the standard one..
PostPosted: Fri May 19, 2006 3:58 pm
yeah, true
but all i see is 5" wide and i measured mine up and they are 5.5" so im not sure!?
I smile everytime!
PostPosted: Fri May 19, 2006 4:12 pm
The ones I've got are 5" between the bead faces and just over 5.5" across the whole wheel width. It is the 5" that the tyre bead sees that is the size the wheels are rated at.
PostPosted: Fri May 19, 2006 6:01 pm
YES 5" bead to bead
PostPosted: Fri May 19, 2006 8:11 pm
I believe some of the Nb racers machine the LS offset ones and weld another inner part rim on, to get 5.5" width.
PostPosted: Fri May 19, 2006 8:35 pm
That's both brave AND skillfull to weld cast alloy bits together. Normally they are too full of micro-pores and silica for any sort of successful weld.
PostPosted: Sun May 21, 2006 7:43 am
Some Nb racers are VERY resourceful..... Check out the cars that use normal offset Contestas, wide (as in S type) rear drums and STILL manage to fit all that under standard non flared rear arches....
Cheers, Ian
