It is currently Sun Jul 27, 2025 4:02 am
PostPosted: Sun May 21, 2006 9:46 am
What bearings do you get in the kit from karcraft?
What other bearing are needed ? (rod change box)
Cheers Pete
PostPosted: Sun May 21, 2006 9:54 am
PM Kazjim
He is rebuilding a gearbox at this very time.
He was advsied what bearings to get, and what ones that dont really need replacing.
No more Minis!......For now.
PostPosted: Sun May 21, 2006 10:42 am
Yeah I bought this for my gearbox rebuild that Doc and I just completed recently, cept i got mine from UK Minispares which is exactly the same kit as what Karcraft sells. Get the right one for either a Rod change or Remote change. From memory the rod change kits come in A and A+ so make sure you ask for the right one. Comes with all the bearings including layshaft bearings, idler bearings, the lot.
I got the one with the diff rebuild kit which comes with competition diff pin and new planet gears and diff gears. It also comes with a MS competition layshaft and all the gaskets.
I went the extra bit and bought a NOS cooper S 4 sync laygear and first motion gear to convert my K box to cooper S ratios 8)
Don't forget to put in a center oil pickup :wink:
PS. Check the Minispares website first as it may be cheaper the buy direct, even including the postage :shock:
Lillee - 1969 Morris Mini K
PostPosted: Sun May 21, 2006 10:51 am
what did you pay Chong???
PostPosted: Sun May 21, 2006 11:31 am
Minispares have non in stock, have sent them an e-mail. See what they say about postage but it will be very close to the price you can get it for over here. Bugger the Aussie dollar :cry:
Pete
PostPosted: Sun May 21, 2006 11:37 am
The Karcraft kits I saw and MG Heritage too I think didn't include the idler gear bearings- I'd replace both whilst you're in there.
PostPosted: Sun May 21, 2006 11:46 am
Pistons - Melbourne . . . .
that is all ...
J
PostPosted: Sun May 21, 2006 12:01 pm
Thanks for the help :wink:
Pete
PostPosted: Sun May 21, 2006 5:56 pm
Sorry too long ago to remember but i know it was around $250 or there abouts
PostPosted: Sun May 21, 2006 7:52 pm
A whle back Heritage MG quoted me around $140. As I said it didn't include the 2 idler gear needle bearings, . Nor did it include the 2 diff bearings- they run so slow they are the last thing to wear out.
PostPosted: Sun May 21, 2006 10:33 pm
Might be a good idea to do them as well, just in case
:roll:
