It is currently Sat Aug 02, 2025 8:59 pm
PostPosted: Mon May 22, 2006 10:59 am
Yes you don't need "new" driveshafts, you need to clean, repack with grease and change the rubber boots of both your inner and outer CV joints. The inner one is also known as a pot joint.
If you are doing one side, the other side is probably on it's last legs, so do both. It's a medium difficulty home job but can be done pretty easily with the right book and tools ...
PostPosted: Mon May 22, 2006 11:01 am
PS. Don't lose all the balls from the inner pot joint (6 in total on each side). If you do you may need to buy a brand new pot joint which are about $150 each from memory.
PostPosted: Mon May 22, 2006 11:13 am
ok, i kinda understand all of that, so does anyone have a set or the one thats missing for me??
thanks so much for your help, glad you could understand my dumb girl talk (im an only child you see no brothers to wear off on me)
this is all thats on the car...
PostPosted: Mon May 22, 2006 11:30 am
Yes I have one of each - I am about to head off to a dentist appt and I doubt I will feel muich like garaging later today. I will look tomorrow and PM you with a cost including postage.
You are advise to contact Karcraft to get a new set of balls (12 in total) and two new of each the inner and outer rubber boots.
The CV grease is obtainable from any motor spares outlet.
If someone else offers closer or faster- just let me know by PM
regards Mike
Users browsing this forum: minimanic and 90 guests
