It is currently Sat Jul 26, 2025 5:50 pm
 Post subject: not fair smokey mini
PostPosted: Thu May 25, 2006 9:47 pm
my mini is blowing smoke like no tomorrow what could of happened
Filled er up with diesel is my guess!
PostPosted: Thu May 25, 2006 9:50 pm
what condition is the head in and what colour smoke
black or blue or white
PostPosted: Thu May 25, 2006 9:58 pm
done any spirited driving lately?
 Post subject: mm1275
PostPosted: Thu May 25, 2006 10:17 pm
ill sell you a complete mini clubman with recepts to a engine rebuild ($4000).
For 2k. That may fix ur problem
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Thu May 25, 2006 10:20 pm
ill beat that!!! $600 for my clubby. bolt on new box, good as new :lol:
PostPosted: Thu May 25, 2006 10:37 pm
If your clubbies engine has 4k worth of recepts then true. you beat me.... If it doesnt then 2km down the road the engine could start blowing smoke.....
A complete engine and box rebuild should last another 80,000M
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Thu May 25, 2006 10:42 pm
Want me to drive your four-thousand dollar motor and have it blow up in 2km?
Where there's a Will there's a way.
PostPosted: Thu May 25, 2006 10:43 pm
:oops: ok i miss read your post... you win!!! :wink: but really ben u want my clubby or u just gonna bits it tomorrow when u come up?
PostPosted: Thu May 25, 2006 10:46 pm
im abit annoyed with the smoke from my clubby..... i just thought it was bekuz of a destroyed valve..... so i went and got the head rebuilt and its now blowing even more smoke....?
ahhh what the...... so im not happy
PostPosted: Fri May 26, 2006 8:06 am
I had my Clubby bow more than excess smoke I burnt out an entire cylinder. smoke everywhere and I drove it home for hours before i cud get it fixed and to bore the engine and everything a ffew things as well to it but cost just under $4K to do that wa for a 1275 though. bes t of luck
 Post subject: Re: not fair smokey mini
PostPosted: Fri May 26, 2006 8:22 am
There really are a lot of things that could cause this , what colour is the smoke ? What fluid's if any are dropping (check oil and coolant) . As a very quick test leave the car idling and with a pair of insulated pliars pull a plug lead off at a time , if it runs a bit rougher each time then one cylinder shouldn't have a major problem alone , if pulling the lead off makes the motor sound rougher on all but one and the other one doesn't change the motor's sound then that one may have a problem . Beg/borrow/buy a compression tester and see what that tells you . How long since the motors been rebuilt ? Does it smoke all the time , only under acceleration , only on deceleration or coasting down hill ?
PostPosted: Fri May 26, 2006 8:42 am
a sudden change from no smoke?
if so, cracked head, or head gasket.
Website: www.justanothermini.com
PostPosted: Fri May 26, 2006 10:06 am
Whack the head off and have look see. You've only got a few weeks to mini muster no?
PostPosted: Fri May 26, 2006 1:48 pm
grey smoke, has the usuall smoke but just last night there was a s#!t load when i would take off, is running fine but yea smoking alot
