It is currently Fri Jun 27, 2025 4:06 am
 Post subject: My conversion-
PostPosted: Sat May 27, 2006 1:41 pm
I've whored it out a lot, but thought I'd share it with you all.
Honda VFR 800 into roundie...don't ask why please...
http://www.minimania.com/web/threadid/7 ... thread.cfm
:twisted:
PostPosted: Sat May 27, 2006 11:38 pm
why...??
PostPosted: Sat May 27, 2006 11:46 pm
IwannaMini wrote:
why...??
:lol:
it was coming...
~sumanovic
PostPosted: Sat May 27, 2006 11:59 pm
Yeah Beau I like it!
I ride a little viffer 400 and they do sound sweet. The 400 V4 is considered pretty well bullet-proof, and I don't imagine the 800 would be any different.
Keep us posted.
PostPosted: Sun May 28, 2006 12:50 am
IwannaMini wrote:
why...??
why not...??
PostPosted: Sun May 28, 2006 1:14 am
IwannaMini wrote:
why...??
haha.. you sh*t stirrer..
the answer to your question is..
Because he can :idea:
PostPosted: Sun May 28, 2006 7:36 am
If only we could register bike engined cars down here , love your approach of mounting the engine sideways and keeping it all compact and still front wheel drive , will be fantastic when it's finished , good luck .
PostPosted: Sun May 28, 2006 9:40 am
has anyone actually tried to before???
what would be the major prob?
~sumanovic
PostPosted: Sun May 28, 2006 11:05 am
reverse??
PostPosted: Sun May 28, 2006 11:26 am
~sumanovic
It's all to do with emissions apparently , bike and car rules are different and to register a bike motor in a car I think you have to go through all the emission testing ..... Do a search in this category for bike engined mini's , there's a good thread on it . Also , normally they use an electric motor on a non drive wheel for reverse so that's not the problem (though it wouldn't be easy to set up ....)
PostPosted: Sun May 28, 2006 12:26 pm
I'm worried about going forward right now. :lol:
Reverse can wait, but yes it will be be a starter motor when the time comes.
UPDATE!
Not much. Just some progress from today. Still a long way to go. Lots of cutting, measuring, grinding, measuring, welding, measuring and measuring! The pics look a little rough. Nothing is level so things look out of wack.
And used painters tape to make stencils for gussets. I alos bought some off ebay that are a little nicer.
Next is to get it up and a flat surface and make sure everything is perfectly level and square. I have meaured everything NUMEROUS times during the build. The two front mounting holes moved it about 2mm though. I still have to finish the front lower section so I should be able to correct it then. I'm afraid to see what will happen when it's all welded up.
Time for a nice cold shower and some food...
PostPosted: Sun May 28, 2006 12:32 pm
Looking good , here's the other thread about bike engined car's in OZ , possible but expensive .....
http://www.ausmini.com/forums/viewtopic.php?t=15282
By the way Beau , what are you planning to do to balance the car since most of the weight from the motor is only on one side , albeit the passenger side on a LHD car ? Is there room for the battery and any other heavy bit's in that side of the engine bay ?
PostPosted: Sun May 28, 2006 12:52 pm
Yeah, I'm thinking I'm going to have to convert over to left hand drive. I plan to have the battery, reverse motor, diffrential, radiator, overflow tank, oil cooler and possbily a turbo. Once I get it built I'm bringing it up to school to get everything weighed and dynoed.
PostPosted: Sun May 28, 2006 2:55 pm
Hi Beau,
This is Jeremy ( The guy that bought the 13" rims off of you). I like what you doing, I thought of doing the same but with a TL1000R motor. I'm interested to see the finished product. Keep up the good work! And good luck. :lol:
PostPosted: Sun May 28, 2006 3:10 pm
Hey dude!
I actually considered the TL1000 engine. It was a toss between the RC-51, VFR800, or the TL1000. I have heard a few bad things about reliability with the TL1000 engines though. I got a sweet deal.
If I get this set-up running good, I'll be looking to spend some more money and get a Honda RC-51 engine. More compact, more HP, more torque and awesome sound!
