It is currently Sat Jul 19, 2025 1:39 pm
 Post subject: Slight backfire.
PostPosted: Tue May 30, 2006 6:01 pm
When I let the throttle go on my RE13'd 1275, I get a slight popping backfire It's very soft, not a bang. Also when I stop the engine I get a strage little pop in the exhaust pipe that changes note as unburnt gasses burn off slowly.
My timing is correct, and my mixture seems OK (set with a Gunson Colourtune), can anyone guess as to what might allow this to happen? Obviously something is out.
Mick
PostPosted: Tue May 30, 2006 6:13 pm
it's all normal mate.
PostPosted: Tue May 30, 2006 6:15 pm
yeah i get that to, specially when i'm going downhill with the clutch out and slowing myself with the gears.
PostPosted: Tue May 30, 2006 6:33 pm
Also check the compression with a compression guage. A burnt exhaust valve will also a pop sound out the exhaust.
You usually have other symtoms as well like a miss but its worth a check
PostPosted: Tue May 30, 2006 7:01 pm
Cool, thanks guys. The compression is tops as I had the head rebuilt recently when the camshaft went in.
taa
Mick
PostPosted: Tue May 30, 2006 7:09 pm
No - make sure the compression is still tops now as well
It could also be an exhaust valve not closing properly due to either a sticking valve (valve guide grabbing) or tappet clearance too tight.
If nothing else it eliminates some possibles.
PostPosted: Tue May 30, 2006 7:47 pm
Backfire in the exhaust is also symptomatic on an exhaust leak, usually up near the manifold.
It's burning unburned fuel.... :wink:
PostPosted: Tue May 30, 2006 8:10 pm
Okey Dokey, I'll check those too.
Mick
PostPosted: Tue May 30, 2006 10:24 pm
maybe ur car is 'fully sick' 8)
PostPosted: Tue May 30, 2006 11:18 pm
Yeah like 'Fully hospital sik' bro :wink:
PostPosted: Wed May 31, 2006 1:54 am
I wouldn't worry, ever since i put the RE-13 in mine does the 'pop' too..call it snap crackle and pop..minus the first two... pop..pop.pop 8)
It's very quiet though..
PostPosted: Wed May 31, 2006 7:41 pm
Isn't this just valve overlap - ie both the exhaust and inlet valves are open for a very short duration?
If so, it did this in Stu's LS very "badly" (but i loved it), 286 Megadyne Scatter Pattern Kent cam... fantastic rally/fast road cam 8)
PostPosted: Wed May 31, 2006 8:06 pm
Nah- my RE282 doesn't do it, nor did my RE13... both running 1.58:1 rockers. :lol:
PostPosted: Wed May 31, 2006 8:13 pm
I have also got 1.5 to one MS forged rockers. Hmmmm better look aty that manifold again...
I've got a question though, seeing that the exhaust is pressurised by the gasses exiting the engine, what compels the air to get into the exhaust via the gasket when there is a leak?
PostPosted: Wed May 31, 2006 8:54 pm
At the manifold face there is a pulsating flow from pressure to vacuum in each exhaust port, not constant pressure. :wink:
Users browsing this forum: wild_willy and 63 guests
