Ok i know it has probably been asked elsewhere before, and i did search
i got the input shaft circlip out using borrowed circlip pliers of almost the correct size, but i need some advice on method or tools to "withdraw the bearing" which the good book says is done with "special tool 18G284 and adapters 18G284B".
I am assuming this is some kind of bearing puller. normally i would just find some kind of drift that fits and knock it out, but this one is kinda hard to get to, so advice appreciated.
And yes Kev, i would love to bring it over your place - if only i had the time on a weekend. At least i can do a little each night after work and it slowly gets there - if i know how to do it
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
