It is currently Wed Jul 23, 2025 9:39 am
 Post subject: Argh! Help pleeese
PostPosted: Tue Jun 13, 2006 9:05 am
ausmini mod
ausmini mod
Hi,
OK, so I replaced the terminals on the battery cables because they were loose and couldnt be tightened anymore.
This allowed my beast to start, run and be happy.
However I just drove to work this morning and (its actually the second time) as I am driving, the guages all drop (except speed) and the alternator light comes on :( and I have no electrics (blinkers, lights, wipers, etc)
So a bit later few kms down the road... the guages pop up and things are normal again... for about 2min and then back to nothing.
If I put my blinker on or fan or anything during that time the ALT (alternator) light comes on really bright.
Heeelp!
Peter.
PostPosted: Tue Jun 13, 2006 10:19 am
First thing I would be looking at is the fuses.
Pete
PostPosted: Tue Jun 13, 2006 10:29 am
Also check the crimp on connector that joins the ignition lead to the center of the starter solenoid , clean the terminal and make sure the connector goes on tight .
PostPosted: Tue Jun 13, 2006 10:39 am
Bottom line Peter
You have a loose connection somewhere in the circuitry. The risk with it cutting in and out is that each time it breaks or makes contact, it sparks and you run a risk of burining some or all of the wiring harness.
A new harness is fairly expensive and second hand harnesses almost always show the effects of very amateur home auto electricians.
You are doing the right thing by driving the car and cataloging its strengths and weaknesses but its becoming obvious that you have a fairly unsorted car that has had a succession of less caring owners. We have all been there, Mate.
See if you can talk a local Mini owner to have a good look at it for you. A mini owner because they mostly already know the common problems.
PostPosted: Tue Jun 13, 2006 11:54 am
ausmini mod
ausmini mod
Mike_Byron wrote:
Bottom line Peter
Yeah, thats the reason I am driving it... to try to find bugs :) But hopefully I dont find a bug that leaves me stranded cause the wife still isnt keen on the Mini... and wont come pick me up ... haha.
I'll find that darn loose connection... I thought I found em all but was kidding myself.
Peter.
PostPosted: Tue Jun 13, 2006 11:56 am
How is the grounding terminal of the battery to the car? usually this is an area that is Mucho Rustico and can cause issues. Mine had lots of battery connection problems here and I had to undo the terminal to the body and clean it all up with a wire wheel and a file...
Lillee - 1969 Morris Mini K
PostPosted: Tue Jun 13, 2006 12:19 pm
ausmini mod
ausmini mod
Dont say that! Thats the only connection left.
I didnt fix that one cause it looked ok... but I thought... I might as well, then went nah, then went ok, im going to work... do it later :)
Peter.
PS: Now it looks like its not charging so I may have a flat :)
Users browsing this forum: Steam and 82 guests
