It is currently Wed Jul 30, 2025 12:25 pm
 Post subject: mix-n-match 13's
PostPosted: Fri Jun 16, 2006 11:14 am
has anyone seen a mini with 13x7 superlites on the back and 13x5.5 (or 12's or 10's) on the front? just wonderin if it'd look crap. cause i could put sum on the back of mine with 10's on the front and i couldnt have to do any cuttin :D haha
i assume it would look either like sum sexy drag car :roll: or just stupid like u couldnt afford the whole set (me)
PostPosted: Fri Jun 16, 2006 11:44 am
you are correct, i would look stupid....no other way of puting it...sory :D
edit: (with 10's one end 13's the other that is)
PostPosted: Fri Jun 16, 2006 11:50 am
The different width 13's might look passable and go towards evening up the front and rear track widths but I think that can affect handling , 10's or 12's on the front and 13's on the back will look like you're a poser , slightly wider on the back will keep people guessing though , is it rear wheel drive ? Are the backs wider ? That mini looks different but don't know why etc etc etc ......
PostPosted: Fri Jun 16, 2006 3:33 pm
Thats why i wanna tub a mini - 13x5.5s on the front, 13x7s on the back, but using std. flares all 'round. I think that would look sweet, it would only need about an inch or so...
PostPosted: Sat Jun 17, 2006 2:54 am
Its not uncommon to find Japanese minis with 12's up front and 13's on the back.....
Makes tyre rotation a bit difficult though - and what size spare would you carry?
PostPosted: Sat Jun 17, 2006 4:36 pm
now that is a good point, cant sumone pgotoshop a picture, 10" superlites on front 13"on the back
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
