It is currently Wed Jul 30, 2025 12:00 am
PostPosted: Fri Jun 16, 2006 1:17 pm
hey guys
i have been doing the inteerior (dont know how to speel it still) and thought about the air con/ heater, now my radiator has the normal, but the heater goes from a pipe that comes from the bottom of the radiator and then goes to the heatercore sounds normal eh, but it does nt go back to the engine or radiator goes to a pipe that is clogged by a screw that sit down near were your feet are under the carpet. that cant be how its ment to be and at the moment i heater core does nothing. i cant find any little holes for the water to go back in side of the radiator or the engine,
PostPosted: Fri Jun 16, 2006 1:20 pm
I'm not 100% sure but it sounds like the hose thats blocked off should go to the heater box inside the car. Thats probably why you're heaters not working.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Fri Jun 16, 2006 1:31 pm
The hose on the other side of the heater core should go to a fitting on the top drivers side of the cylinder head. Sometimes this is blanked off in place of the small brass fitting.
PostPosted: Fri Jun 16, 2006 1:41 pm
See where this hose goes:
PostPosted: Fri Jun 16, 2006 1:51 pm
dang, thats where my temp sender is.. so where is the temp sender ment to go,
PostPosted: Fri Jun 16, 2006 2:04 pm
:shock: How did you get a temperature sender in there?
They go in the head nearest the water pump:
PostPosted: Fri Jun 16, 2006 4:33 pm
LMAO - where theres a will, theres a way!!
Top points for trying - if it works...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Fri Jun 16, 2006 5:41 pm
i cant find that any where, there is no where for the temp sender to screw into
PostPosted: Fri Jun 16, 2006 6:01 pm
Sounds like it might be an 850 head , they didn't have a temperature sender . I've got a head somewhere here with a big nut welded to a bit of steel plate bolted onto the head where the heater hose normally goes and a temp sender in that , I'll just about bet that's what they did with yours .
PostPosted: Fri Jun 16, 2006 6:12 pm
i will post a pic if any one can tell me how to post it on here with out using 1 of those stupid website gallery things
PostPosted: Sat Jun 17, 2006 12:04 am
Your ISP usually gives you some web space to play with - stick the picture there.
The early heads on the 850s had exactly that setup you described.
Heaters were a rarity in those days. From memory, I think the 850s with a heater had the temperature sender mounted in the top of the thermostat housing. Not sure if that type of thermostat housing is still available :?
PostPosted: Sat Jun 17, 2006 12:11 am
I think Morris Minors used the same type of thermostat cover with a drilling for the temp sender. Minispares used to have them, but I can't seem to find them.
PostPosted: Sat Jun 17, 2006 10:41 am
Classic motoring here in Canberra has them in stock I believe. Give Anto a buzz
I bought one and its gooders. Temp sender in the top of the thermo housing and a capilliary in the head. Double redundancy...lol
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
Users browsing this forum: No registered users and 131 guests
