It is currently Sat Jul 19, 2025 7:16 am
 Post subject: sparkplug problem
PostPosted: Tue Jun 20, 2006 4:37 pm
Die Die Die!!
ok so what does it mean if the centre and the overhanging part of a sparkplug is a creamy colour... and the rest of the top is black ? as it feel like my plugs are fouling
PostPosted: Tue Jun 20, 2006 5:27 pm
Die Die Die!!
cleaned it off and it works fine but id love to know wats wrong with my mixture to be causing this...
 Post subject: Re: sparkplug problem
PostPosted: Tue Jun 20, 2006 5:56 pm
It happens to most of em....it shows the thing has been burning up the fuel....you should try and keep them clean by grit blaster, wirebrush or carefully scraping the crud away (but not down to bare metal)....say once every 1-2 month(ish).
Be careful not to change the gap once you have it right or be rough with the ceramic insulator (they crack fairly easy)
PostPosted: Tue Jun 20, 2006 6:14 pm
ausmini mod
ausmini mod
Doesnt it mean its running a bit rich?
Do you see any smoke if you rev it hard?
Peter.
PostPosted: Tue Jun 20, 2006 6:23 pm
Die Die Die!!
yeah i wire brushed it :) ...only took 2-3 weeks tho
PostPosted: Tue Jun 20, 2006 9:12 pm
some dgreeser in a can and a wire brush...two min job then put the plugs back in.
the fuel is probably rich..OR u've got piston probs...
when i split mine in half...for a few months it would always foul...if ur engine is a lil hottie..u could try 'hotter' plugs...should burn more fuel.
1978 Leyland clubman S.
Users browsing this forum: Bing [Bot] and 84 guests
