It is currently Sat Jul 19, 2025 12:00 pm
 Post subject: H4
PostPosted: Fri Oct 15, 2004 8:00 am
I've seen two types of H4 headlight bulbs. 90w/130w and 55w/100(?)w. I'm guessing the 90w/130w give the brighter light. Any tips on what I should use??
PostPosted: Fri Oct 15, 2004 12:16 pm
Myself go the brightes...but please make sure they are properly ajusted to the road :shock:
PostPosted: Fri Oct 15, 2004 12:51 pm
...and fit some relays or you will probably cook your headlight switch.
BTDT! :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Oct 18, 2004 1:52 am
The 90/130 globes will obviously draw more power from your alternator, so make sure your charging system is up to the job too :wink:
And as bnicho said - Use relays or you will start a fire.
Whats BTDT? ....... better to die trying???...........oh, i get it now... been there done that. geez i'm slow. Yeah, ive BTDT too.... :roll:
PostPosted: Mon Oct 18, 2004 9:26 am
:lol:
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
