It is currently Wed Jul 16, 2025 4:07 am
 Post subject: need help to i.d my car
PostPosted: Fri Jun 23, 2006 9:57 pm
bourght my new project today...think its a 1968 car but not sure..
so far it seems to be an ok buy..as i got it from ebay...
cars pritty solid..but needs some minor work..sills both sides..battery box..and rear valance setion under rear bumper..as its gone in the corner..and a tiny bit in the boot...
all floors look ok though..
car is in undercoat but will need to be sanded back again as its been out in the weather.
ive cleaned the build plate on the car but i dont know what it all means so hoping someone out there does..
from top to bottom they read as follows
YMA2S2
31313
9YA/Ta/H/32440
1/INDIGO BLUE/3
GUSE THE LAST IS A COLOUR CODE??
anyway any help would be great...
cant find body no on car yet..as engine bay needs a good clean..not sure where to look anyway..??were do i start ?
thanks again...from Brien
PostPosted: Fri Jun 23, 2006 10:04 pm
sounds like a deluxe to me should have a 998cc engine aswell
the last bit is colour you are correct
get pics up here soon for us :D
PostPosted: Fri Jun 23, 2006 10:06 pm
body number might be behind MC's or on radiator shroud
PostPosted: Fri Jun 23, 2006 10:07 pm
Body number on firewall
Stamped in BIG figures...
PostPosted: Fri Jun 23, 2006 10:59 pm
Yup that's one of the last Deluxes, late 67 or as you say 68 from my book, Eng number and chassis in similar range, so probably original engine? does it match the plate??
Is that the one that was in bits in primer on E-bay? :roll:
Sir Alec! we are not worthy!
PostPosted: Sat Jun 24, 2006 4:58 pm
thanks for replys...and yes its the one from ebay...not sure if i paid too much for it..but seing as i paid top dollar for my other two and they were full of rust i dont mind too much
had better look at it tonight...same as b4 stuff needs replacing plus ill do both front floors as well as theres fiberglass on the top and bottom on both of them...so ill replace just for piece of mind...will have even better look tue wed...and then get cracking in the cleaning up department...it needs a lots of scrubbing and sanding...
PostPosted: Sat Jun 24, 2006 6:46 pm
Minifreak1
Re the colour code 1/Indigo Blue/3
The prefix gives the paint type and the suffix gives the manufacturer
The 1 means it is Enamel (Baked)
The 3 means it was made by Berger, since taken over by Dulux along with several others.
Hope this helps
RonR
