It is currently Mon Jul 21, 2025 12:44 pm
 Post subject: wiring loom
PostPosted: Sat Jun 24, 2006 6:17 pm
does anyone know where i can get a new or a good un melested round nose wiring loom from
Cheers Dan
PostPosted: Sat Jun 24, 2006 6:47 pm
http://www.classicwiringlooms.com.au/
is a start.
Pit pricey though, but the end result is amazing. Your choice of original braided or PVC tape finish and extra wires for immobilisers, spotlights, relays stereos etc included for free.
MORRIS MINI
1962 - 64 Morris Mini 850 - starter in floor Aust built $385.00 $423.50
Morris Mini 850 - starter in floor U.K. built $385.00 $423.50
1963 - 64 Morris Mini Mk1 Cooper - C40 generator 998cc Aust built fuel pump on drivers side $385.00 $423.50
1965 Morris Mini Mk1 Cooper S - C40 generator $385.00 $423.50
1968 - 72 Morris Mini Moke - Californian $462.00 $508.20
1968 - 72 Morris Mini Moke - small wheel $462.00 $508.20
1969 Morris Mini K - last of round fronts $385.00 $423.50
1969 Morris Mini Mk11 Cooper S - 15ac alt. U.K. + 4 T R reg $385.00 $423.50
1976 - 78 Morris Mini Clubman G.T. - tacho, rocker switches.
(plugs needed) $451.00 $496.10
1979 Leyland Mini Moke - dip on column - reverse lamps / stop $302.50 $332.75
PostPosted: Sun Jun 25, 2006 9:36 am
thanks mate
Cheers Dan
PostPosted: Sun Jun 25, 2006 2:45 pm
Wow $500 for a Clubman GT which will be similar to a Clubman S at a guess...
Mick, do these guy modernise the loom as well? ie modern blade style fuses, relays for the headlights etc?
PostPosted: Sun Jun 25, 2006 4:28 pm
Only if you ask, they will do most minor modifications gratis, but if you ask for major changes and I guess they would have to charge a little more.
The result is well worth it.
Users browsing this forum: timmy201 and 70 guests
