It is currently Sat Jul 19, 2025 12:10 pm
PostPosted: Sun Jun 25, 2006 9:41 pm
Hi All.
Just finished off the engine with new head gasket among other things.
Been driving it a few days now, and have a build up of the milky stuff on the oil cap. The head gasket is NEW, and was put on correctly, and car runs fine with no bad noises or stuttering or anything like that.
What else can cause this milky build up ?
btw, my breather hose from tappet cover to carbie had a weird build up of slugdey crap in it (guessing from before repairs). Can a restricted breather hose cause the build up ?
No more Minis!......For now.
PostPosted: Sun Jun 25, 2006 9:44 pm
If you blew the head gasket my guess is that you still have residual water in your oil. It took a flush or two for mine to come clean after i had the same issue. Could be as easy as another oil change, along with a new filter too.
Aaron
PostPosted: Sun Jun 25, 2006 9:51 pm
Remember also Max that since the cold weather is set in, the car may not be getting warm enough(funny to say that about a mini!!)to boil off the moisture in the oil. It is a by-product of the combustion process. A change of the oil will set you right. If the car is still getting condensation, do what I do and block off part of your grille to restrict the airflow and warm the car up a bit more(I have perspex on half the grille and temp now about 1/3 on the guage.
I still get condensation though but is in the form of clear droplets and not mayo and water.
Hope all is well in your part of the world...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sun Jun 25, 2006 9:59 pm
Ahhhh...I see!! Goodstuff.
Ill wack some newer oil in then. Tommorows job :)
Mini is running cool as...hasnt even hit 180F yet...im stoked :)
So far so good!!
PostPosted: Sun Jun 25, 2006 10:00 pm
Yep just a buil.d up of moister. giver her a oil change and also the oil filter as mentioned above.
And see how you go then, specialy if she still running well
PostPosted: Sun Jun 25, 2006 10:11 pm
Too many short runs... :wink:
A litre of fuel produces ~1.5L of H2O when burned, as water vapour. Some gets past the rings and condenses on cold bits of the engine.
Mixes with oil film to form `mayo'.
One of the coldest bits happens to be the rocker cover. 8)
Take it for a long run, and when it all gets up to temp, I bet the muck all boils off.
PostPosted: Mon Jun 26, 2006 12:47 pm
Resident Haemorrhoid
i had the same problem untill i hooked up the breather on top of the motor to the carbie no more mayo and the motor seems to run a bit smoother 8)
mtsmini wrote:
Tombo wrote:
PostPosted: Mon Jun 26, 2006 7:48 pm
I have just returned the breathers back to standard on my car and no mayo! :P
PostPosted: Mon Jun 26, 2006 8:26 pm
This is a bit of spectulative diagnosis
I think that the mayo settles on the high points in a motor - a bit light the boiling kettle in the kitchen leaves condensation on the ceiling and the shower condensates on the walls and ceiling in winter.
In the motor, in winter, the mayo also settles on the high points of the motor and is not actually in circulation. As soon as the motor comes up to temperature the water content boils off and the oil falls back in the sump.
My question is - does it do any damage ad is it worth the worry.
I truly don't know so hence the question.
PostPosted: Mon Jun 26, 2006 8:59 pm
I believe mayo is just a sign of poor crankcase ventilation.
Neither of our 1275s get it, even on short runs- which mine does 3 of a week.
One motor has crankcase breather piped to a PCV in the Weber manifold, the other has it piped to the vac ports on its twin HS4 SUs.
No worries... 8)
PostPosted: Mon Jun 26, 2006 9:25 pm
I have a spare teppet cover with a breather pipe coming out of it...might hook it up and wack a cheap filter on the end.
PostPosted: Mon Jun 26, 2006 11:20 pm
Maxi23 wrote:
Hi All.
J or stuttering or anything like that.
sorry for hijack
but when you means stuttering does it like do that when you try to accelerate, even down hill....
i am having that problem constantly, sometimes will dissapear for awhile but always is there?
PostPosted: Tue Jun 27, 2006 10:42 am
I said -
"...and car runs fine with no bad noises or stuttering or anything like that."
PostPosted: Tue Jun 27, 2006 12:07 pm
Maxi23 wrote:
I said -
sorry, was half asleep when i wrote that...
i ment would the car stutter and stuff if the head gasket was blown? ?
because thats what mine is constantly doing....? trying to eliminate problems
PostPosted: Sun Jul 02, 2006 10:37 am
Well at least I can rest easy then if this is considered "normal".
I'd never had this problem, until my rebuild. I not 'm loosing any water, compression is all even so I was guessing this was the reason for the build up. However I already have the rockercover breather plumbed backinto the carby inlet?
Not to worry...
1972 Mini Clubman 1380
previously 1330 85 bhp @ 6000 rpm new engine no idea?
My00 WRX
190 bhp @ 5800 rpm
