buztoy wrote:
yeah, i see that one, was radiator hose the only thing he could find or something, i was thinking of only one tap but 2 i dont really need, now ive work out a way to pull it off, the thing isnt like a bolt hex or square its round,
Ok I think youre confusing some things here.
The large fitting at the top of the last photo with the thick rubber hose comming out of it is the inlet for the oil cooler piping. The thick rubber hose is not radiator hose but an oil hose. Dont worry about any of this if you are not running an oil cooler.
The smaller fitting immediately under and to the right of (with thin copper pipe with a bulb at the end coming out of it and taking a 90deg angle) it is the oil pressure gauge outlet. Thats what awdmoke was talking about. That copper pipe carries the oil from the block to your oil pressure gauge. In later clubbies there was an electric switch there instead of the pipe and wiring for the oil pressure light.
What awdmoke proposes here is for you to screw in a T fitting of the correct thread and fit the oil pressure gauge pipe to one side and the sender for the oil temp switch on the other side.
BTW would this give a very accurate reading for the temperature?
