It is currently Mon Aug 18, 2025 2:17 pm
PostPosted: Mon Jun 26, 2006 9:14 pm
Bromley wrote:
In fact the charge light has been coming on of late. Mainly when sitting at idle.
3 possibilities-
1. Fan belt loose...
or-
2. Alternator pulley very badly worn (the steel ones wear U-shaped, then the belt slips).
or-
3. Alternator's brushes are on the way out. Easy fix on most Lucas alternators as their brushbox is external, on back of alternator.
If it's charging properly, the voltage measured across the battery, with lights off and motor doing 2000 rpm or more, should be 14.0V or better. :wink:
Last edited by drmini in aust on Mon Jun 26, 2006 10:17 pm, edited 1 time in total.
PostPosted: Mon Jun 26, 2006 9:26 pm
Mike_Byron wrote:
As soon as the battery starts to fail, my wife shrieks "off with its head" (she does the same with non laying chooks)
Mate, I'd hate to think what she would say if you were to stop living up to her expectations in the bedroom :wink: :D :twisted:
Back on topic, what the doc said plus:
4. Regulator shot, not supplying field voltage to the alternator.
I had this happen. Bought a cheap external job to replace.
PostPosted: Mon Jun 26, 2006 10:23 pm
Mate, I'd hate to think what she would say if you were to stop living up to her expectations in the bedroom Wink Very Happy Twisted Evil
Like all married men, I must say that expectations in the bedroom are a very touchy issue on either side of the relationship.
PostPosted: Wed Jun 28, 2006 8:19 pm
After a quick check in the dark I think the problem is one of many oil leaks spraying on to the fan belt helping it slip.
I can easily move the belt on the alternator wheel with one hand and I feel the presence of oil.
Will muck around with it tomorrow.
Users browsing this forum: No registered users and 194 guests
