It is currently Fri Jul 25, 2025 11:33 pm
PostPosted: Sun Jul 02, 2006 2:05 pm
Between the recess and the body panel
Also, is there a rubber that goes around the kneck that sits on the inside of the van parcel shelf?
A photo of someone elses van will be helpfull.
 Post subject: Could be....
PostPosted: Sun Jul 02, 2006 2:14 pm
Sealing ring, neck to floor is shown in the Mini Car Clinic cattledog...just a fat rubber donut by the looks of it. Then there is a fuel neck sealing gasket which looks like it presses in to the metal "pocket" where the filler comes out.
PostPosted: Sun Jul 02, 2006 5:24 pm
I have both of those. Just wondered if there was a gasket between the "pocket" and the body panel.
PostPosted: Sun Jul 02, 2006 5:41 pm
even if there isn't meant to be one, I'd be making one out of plastic - cut one out of a black oil container, but I have a feeling there is supposed to be a cork one
PostPosted: Sun Jul 02, 2006 7:11 pm
Already put in place without the gasket :(
PostPosted: Sun Jul 02, 2006 8:37 pm
did you use any sealant or anything?
PostPosted: Sun Jul 02, 2006 9:17 pm
No. Should I squirt some silicone behind it?
PostPosted: Sun Jul 02, 2006 9:26 pm
I've pulled apart quite a few vans and a traveller. They all just had a smear of seam-sealer in that join. I doubt the factory ever put a gasket in there.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Jul 02, 2006 9:40 pm
My van had a thin cork/cardboard gasket from memory. After it got painted I used a bead of silicone that I wiped clean with turps after pushing the filler thing on, never had any leaks and it was super sexy hot looking :D
PostPosted: Mon Jul 03, 2006 9:22 am
I reckon you should have something to seal it - the metal will move a bit, so it could rub through the paint, then if water gets in there....
PM Steve & Mikey and find out what they did with Bruizer
