ziff wrote:
I warned you all there would be plenty of dumb questions coming from me now that I have bought the van so here goes
The brakes had been sitting for quite a while with no fluid in the system and when I looked inside the reservior it was completely rusty. I have a Morris 1100 sitting here and decided to pinch the one off it to replace the vans rusty one. There is a difference between the two and I would like to know if they are interchangeable and the only difference is the size or whether I can't put the Morry master cylinder on the van. See picture below.
Next question. Should there be any difference in the brake systems on vans to sedan Minis. The brake line on my van ends in the middle at the back as per the picture below. Should it go to a Pressure Valve Assembly that is fixed to the subframe where the other arrow points to
Last question for now with the picture below. What are the metal brackets on the tray behind the drivers seat for
Thanks very much.
Ziff
The Morris 1100 reservoir is larger in volume but I believe it should be OK....it might give you less braking power...Mike can answer that one.
Pretty sure you need to get a proportioning valve just like a sedan.
Those extra brackets look like someones welding/pop rivetting work to me...
