It is currently Thu Aug 14, 2025 10:03 pm
 Post subject: oil cooler
PostPosted: Sat Aug 05, 2006 4:56 pm
hi,
When doing an oil change with an oil cooler in system do you need to disconnect or just let it drain out.
How much extra oil is needed to fill this and the piping from there to the engine.
DAVID CURRIE
PostPosted: Sat Aug 05, 2006 6:56 pm
You don't need to disconnect the oil cooler, just let it drain. I allow about an extra 500ml for the cooler and piping..
PostPosted: Sat Aug 05, 2006 7:05 pm
Oil cooler holds bugger all- I just drain the box, do the filter and refill.
Or rather, I did- the cooler is off now. 8)
 Post subject: Back-Flush
PostPosted: Sat Aug 05, 2006 8:52 pm
Just a thought....for those that have coolers fitted....should you flush them out every zillion miles or so....are the galleries such that crud can build up etc :)
Bump :oops:
PostPosted: Sat Aug 05, 2006 9:44 pm
When I ran one I used to flush it every rebuild/engine swap, using turps- until it ran out clean.
But, none of these were catastrophic blowups. Most racers reckon if you have one of those and it gets full of metal etc, chuck it away- as you will never get it all out. :wink:
Users browsing this forum: No registered users and 277 guests
