It is currently Fri Aug 15, 2025 1:46 am
PostPosted: Fri Aug 04, 2006 10:44 pm
Resident Haemorrhoid
I will be attempting to change my rubber uni joints
do I have to remove the drive shaft or can i just undo the"U"bolts and drop it out
Gadget
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Aug 05, 2006 9:16 am
Gadget
With lots of swear words and rotating the shaft to get at all four lock nuts...you can do it without removing the driveshaft.
Tip: buy some new nyloc nuts for the job.....and, sometimes the U Bolts spring open a tad once dissasembled (Mr BFH or Mr Vice can be your friend here to make a small adjustment).
Great day for it!! :wink:
PostPosted: Sat Aug 05, 2006 9:26 am
[quote="9YaTaH"]
quote]
i hope you have small, girl-like hands! or very thick skin.I do not envy you at all!
have fun
(retreats to law assignment)
PostPosted: Sat Aug 05, 2006 10:40 am
New uni joints come with new u-bolts and nyloc nuts anyway :wink:
PostPosted: Sat Aug 05, 2006 4:25 pm
Good Anto :!: ....they dint always and may not still from all suppliers :?: :) Better to mention it anyway :)
PostPosted: Sat Aug 05, 2006 6:07 pm
Make sure not to over-tighten the nylock nuts.
They should only be done up to 10 to 12.5 lb.ft. (1.38 to 1.73 kg/m) which would be about as tight as a 5 year old could do them. :wink:
If you do them up too much they will fail very quickly.
PostPosted: Sat Aug 05, 2006 8:42 pm
I split a ball joint to make it easier, can't remember which but one side has more movement than the other and tha side is easier to change than the other.
 Post subject: Yep
PostPosted: Sat Aug 05, 2006 8:47 pm
Good idea...but you can get away with it so long as you can get full lock (to get between the couplings) with the car jacked up high at the front.
PostPosted: Sat Aug 05, 2006 9:15 pm
The way I have done it in the past (and applies to both sides) is to take out the lower bump stop and with the weight of the car on the suspension, put a wedge in where the bump stop was to stop the supension from moving when jacking the car up. This also enables you to remove the lower suspension arm bolt and allows you to swing the suspension away from the subframe. This then gives you enough room to slip the rubber universal out. Pretty much the same as breaking a ball joint but as with most ball joints, they are a dog to release without the proper tool.
PostPosted: Sat Aug 05, 2006 9:34 pm
HINT
Rotate the drive shafts as you tighten up the U bolts - it makes the rubber CV sit into their positions.
Once you have tightened it all up - rotate the shafts quite a few times and then check the u-bolt tightness again. Often they are loose.
Users browsing this forum: Bing [Bot] and 69 guests
