It is currently Wed Aug 13, 2025 1:18 am
 Post subject: fitting bullet mirror
PostPosted: Wed Aug 09, 2006 6:20 pm
i've tried and tried and tried again, how do i attache the bullet mirror. i did a search and found alot of you only use one bolt caue it is such a tideous job.
can someone please tell em what to do, what to look out for, what not to do, at the moment i have an option of either 10m bolts and phillips screws. they both fid pefectly. how should i go about attaching the mirror?
PostPosted: Wed Aug 09, 2006 10:08 pm
I have some bullet mirrors that i bought from somewhere.... ages ago. They were like $100 each? I used the bolts that they came with. I had to mark out where it was going to be positioned on the door and then drill new holes to fit it.
I placed masking tape over the entire area where the base of the mirror will sit. I then measured very carefully the position of the hole in comparison to the base. I also cut the head off a bolt screwed it all the way in so that just a small amount was sticking out past the base of the mirror.
I then put some CV grease on the stud and carefully sat it on the door. The grease then left an imprint on the masking tape, that was i could be sure i was drilling in the correct spot.
I had the door trims off obviously n stuck my hand up inside the door to fit the bolt.
PostPosted: Wed Aug 09, 2006 10:16 pm
its dodgy but you can use self tappers :lol:
Users browsing this forum: No registered users and 251 guests
