9YaTaH wrote:
sports850 wrote:
We put a high flow pump(efi pump off something unknown , works great) on dad's mk 1 S and then put the regulator between the filter and the pump , no drama's with it after 4 or so years . I normally use the clear plastic generic fuel filters with the little sump for water in the bottom of them and throw them away every 6 months or so ....
Ian....but why wouldn't you put the regulatar after the filter....that way it gets cleaner fuel...should last longer???
I've just reread that , I meant to say between the filter and the carbs , had a little boy trying to climb up my leg at the time and wasn't thinking straight .....
