It is currently Tue Aug 19, 2025 2:25 pm
 Post subject: hand brake broken ?
PostPosted: Thu Aug 10, 2006 6:38 pm
Has anyone ever experienced having a hand brake mount snap off ? If so how do we fix it ?
PostPosted: Thu Aug 10, 2006 6:40 pm
Are you talking the handbrake lever from the floor , if so been there done that , I drilled a couple of hole's where the spot welds had been and used short bolts with nyloc nuts . If it's not there then disregard this answer .....
PostPosted: Thu Aug 10, 2006 6:49 pm
Morris 1100s with bench seats have the handbrake between the seat and the door.
I have had two handbrakes crack and ultimately break. I bought one from a british heritage wrecker and it arrived having being repaired by welding. The next one that split I simply had welded.
Bottom line - If its metal it can be welded. !!!
PostPosted: Thu Aug 10, 2006 7:02 pm
The bit that broke is where the teeth of the hand brake lock thing bolt to the car the hand brake is in between the seats hence where the broken plate is do I have to make a new plate as the original looks pretty flimsy?
Users browsing this forum: Bing [Bot] and 470 guests
