Hey Guys,
Dug out the old window seals for the van. Now they all are not manufactured rectangles if that makes sense. Are they meant to be like this, or has someone bought a standard rubber strip and cut it to length? (ie can be layed out in a straight line.)
I thought perhaps for the sides, but for the front
, or is this some dodgy work in the past?
Now they all have the lock strips etc. I know on the front this goes to the outside, but how about the rear sides? Also if i use these (depends on what you guys say) should the join be at the top or the bottom of the window (I'm guessing top as water won't pool as much there).
Last but not least, when putting the grill and moustach bit on, what goes on first? Do you use rivets or screws - had a combo in the past.
Thanks in advance.
