It is currently Tue Aug 19, 2025 10:37 pm
 Post subject: Alarm for the Mini
PostPosted: Sun Aug 13, 2006 9:08 pm
Hi
I'm getting the cabriolet this week (hopefully...)
And I'm on the market to get an alarm
I'm thinking of these 2 item
RHINO RAM - $450
Dual Communication
This means that when the alarm is triggered it will SMS you and tell you what zone has been triggered, also you can send an SMS commands to the RAM- Arm, Disarm, Panic, History, Status etc.
Code Hopping Technology (Anti-Scanning, Anti-Code Grabbing)
2 Point Engine Immobiliser on board and 3rd Point GSM Fuel Cut Off
This means you can actually SMS the alarm to immobilise your vehicle
Battery Backup Siren
Dedicated Onboard Glass Break Sensor (Additional to Shock Sensor)
Covert Module and Antenna. This unit looks like an alarm when installed and the GSM antenna is only a wire which can hidden with all the other black wires
Past Alarm Trigger Memory History Reporting Mode (Stores the Last 9 Zones that Triggered) Accessible via programming or SMS.
Shock Sensor Sensitivity Adjustment Via Remote
Engineered in Australia
All Points of Entry Protection (Doors, Boot, Bonnet)
All Black Wiring Harness
Ultra-Bright Red Flashing LED Light
Two Stage Shock with Pre Warn and Electronic Auto Adjustment to Reduce False Triggers
Auto Re-lock and Re-arm for Accidental Disarm
Passive Auto Immobilisation
Visual Arming and Disarming via Blinkers
Quiet Arming Selectable via Remote Control
Automatic Siren Reset Period (30 Seconds)
Lock Pulse on Alarm Trigger
Selectable Current Sensing Circuit
Central Locking Outputs via Heavy Duty Internal Relays
Safety Circuit Prevents Arming While Ignition On
Door Ajar Warning (If a Door is Left Open)
Door Lock on Ignition
Electric Boot Release Output (if fitted) via Remote Control
Perimeter Night Light
Connects to Turbo Timers
VIPER 791XV - $350 plus optional modules
2-Way Remote Start and Security System
The first FCC-legal 2-Way Remote with 66-Bit Clone-Safe Code-Hopping
Full featured vehicle protection and starts your engine with the push of a button
Confirms all commands with easy-to-understand icons with text
Alerts you to security system alarm events by beeping or vibrating when the system is triggered
Lets you keep track of vehicle status
State-of-the-Art Remote Transceiver with Responder Technology:
Optimum Range and Reliability
Bright, Easy-to-Read LCD Screen
Vibrate Mode
23 Different Icon/Text Message
Super bright blue LED light
Belt clip for remote
Remote Start* Features:
Remote Start Convenience
Safety Shut Down
Timer Mode
Complete Engine Monitoring
Anti-Grind
Engine Checking
High-Capacity Relay Satellite
Tach/Voltage Checking
Security Features:
High-Output Mini Neo Siren
Failsafe® Starter Kill
Forced Passive Arming
Active/Passive Arming
Progressive Door Trigger
DoubleGuard® Shock Sensor
Clone-Safe® Super Code Hopping 266 Codes
Nuisance Prevention® Circuitry (NPC)
LED Status Indicator
Ignition Controlled Door Locks
Soft Chirp
Secondary Warning Zone
Remote Controlled Valet® Mode
Bitwriter® Compatible
Parking Light Flash
Clone-Safe
OPTIONS
516U - Voice talk module
513T - Mini piezo siren - Goes inside the cabin
508D - Stand alone microwave sensor
507M - Digital tilt sensor
520T - Battery Backup
Just hoping someone here had experienced with the above alarm or can recommend something better but not that expensive.
PostPosted: Sun Aug 13, 2006 9:11 pm
I wouldn't get any of them now purely because everyone now knows what you could have. 8)
PostPosted: Mon Aug 14, 2006 6:51 pm
Well i'd go the viper, i dont work for viper but i do sell these and if you get it installed professionaly you get a lifetime warranty.
Rikki
PostPosted: Tue Aug 15, 2006 9:25 am
Another good alarm to check out is the Boomerang Alpha 1000, although I think that they are selling the 2000 model now. I had one installed in my last toy and had no worries at all with it - it worth paying the few extra $ it costs to purchase.
Coverage is alot better and I liked how I could sinc it in to my mobile (much like the Rhino one I imagine).
Had a Viper in my last, last car - although not of the same standard as the one you've listed I had no dramas with it either.
Probably not the advice that you were chasing but I hope that it was of some slight use!
D
PostPosted: Tue Aug 15, 2006 10:21 am
some insurance companies will actually state on their cover that an alarm must be met but some australia regulations standard - ie be all black wiring have several immobilisation points and be installed by a certified installer etc etc. id suggest ringing your insurer and seeing what they recommend and also ringing the local certified installers (you may pay a bit extra but at least you will have a warranty and piece of mind)
PostPosted: Tue Aug 15, 2006 2:09 pm
I've heard about installer must be certified installer for that particular alarm, but heard that a licenced auto sparky is sufficient enough for the job and insurance purposes.
Users browsing this forum: No registered users and 281 guests
