It is currently Thu Aug 14, 2025 9:45 am
PostPosted: Mon Aug 14, 2006 6:17 pm
Resident Haemorrhoid
Puting a kit through the master and slave cylinders tomorrow apart from what the Black book says anything i should know so i dont make a pigs ear out of the effort
any advice no matter how simple or silly would be appreciated
mtsmini wrote:
Tombo wrote:
PostPosted: Mon Aug 14, 2006 6:21 pm
Change the hose while you are at it. :wink:
PostPosted: Mon Aug 14, 2006 6:24 pm
Three hints.
Do each separately. That is do the master cylinder, refit it and prime it. Then do the slave cylinder. That way you know that the master is working when it appears not to be pumping.
As you dismantle it, lay out the bits on a sheet of paper in the order they came out. Then reassembly is really just the reverse of the order (mostly)
When you are pumping fluid and bleeding, its nice slow pumps on the pedal with time for the fluid to catch up. Hydraulic fluid is fairly viscous - fast furious pumping only makes you feel better it doesn't help the bleeding process.
PostPosted: Mon Aug 14, 2006 6:43 pm
Slow-Po
Wear some latex gloves whilst doing (they're in the bottom drawer, on the left :wink: :D ) the job, makes it heaps easier to hold things and protects your hands from the brake fliud. 8)
PostPosted: Mon Aug 14, 2006 7:16 pm
8)
Cheers all
mtsmini wrote:
Tombo wrote:
PostPosted: Mon Aug 14, 2006 7:58 pm
Is the hose the same as a brake hose??
i am asuming it is are the fittings the same?
mtsmini wrote:
Tombo wrote:
PostPosted: Mon Aug 14, 2006 8:12 pm
Similar hose but different. :wink: AYA5129 is the part number.
PostPosted: Mon Aug 14, 2006 8:14 pm
thanks mate
so i take it the fittings are different
mtsmini wrote:
Tombo wrote:
PostPosted: Mon Aug 14, 2006 8:17 pm
I bet the fittings are the same but the length is different, but I am only guessing! 8)
PostPosted: Mon Aug 14, 2006 8:20 pm
thanks for that
Doc where are you :?:
mtsmini wrote:
Tombo wrote:
Users browsing this forum: Bing [Bot] and 265 guests
