It is currently Sat Aug 02, 2025 8:43 pm
PostPosted: Wed Aug 23, 2006 9:45 am
Is there an online site or anything else I can look up and running an engine number to tell me more specifics about it? or not.
Roundies Rule !!!
PostPosted: Wed Aug 23, 2006 10:11 am
Heaps of them, just google "mini engine numbers".
Not many engines are completely factory any more, so specifics are a bit harder, but
if all you want to know is its capacity, then its a simple case of:
8***= 848cc
9***= 998cc
10***= 1098cc
12***= 1275cc
Obviously this applies to the engines factory size. They can usually only go up in capacity from there! :D
PostPosted: Wed Aug 23, 2006 10:12 am
9FX** = cooper s 1275cc
PostPosted: Wed Aug 23, 2006 10:17 am
V920**** ??
Roundies Rule !!!
PostPosted: Wed Aug 23, 2006 10:29 am
Victorian POLICE engine number...
PostPosted: Wed Aug 23, 2006 10:30 am
That one sounds very much like its an official number for a block that either had its number machined off or is an imported block that only had the alloy tag riveted on.
In that case the identification of the engine size and type is very much more difficult.
The rego papers that go with the car (if its registered) should have the engine size if the numbers match the rego papers.
PostPosted: Wed Aug 23, 2006 10:53 am
If you can post a picture of the engine we can at least tell you if its a small bore block, large bore block or an A+ engine.
Even a camera phone shot would do
PostPosted: Wed Aug 23, 2006 11:02 am
I can't physicaly get to it atm :(
Roundies Rule !!!
PostPosted: Wed Aug 23, 2006 12:57 pm
Location: ¿¿ The War Machine's Alive § 99 Luft Balloons ??
Cmon get it right...
9FS = Mk 1 S
9FX = Mk 2 S
http://sexyurl.no-ip.org/mod3l0
PostPosted: Wed Aug 23, 2006 3:13 pm
oh... sorry ...
Users browsing this forum: s-c1293 and 98 guests
