It is currently Sat Aug 16, 2025 10:04 pm
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Aug 19, 2006 3:41 pm
I just crashed in practice. :x Does this actually mean anything or is it just that you lose practice laps. Do you need to worry about anything to do with costs? I noticed at the start there was a team spending amount or something?
PostPosted: Sat Aug 19, 2006 7:17 pm
Slow-Po
You just lose practice laps, the car will be 100% for the next session.
The reason for the crash is most likely because your risk setting was too high, or because your set up was way out, hence making the car difficult to drive. Are you working off the engineer's advice? 8)
PostPosted: Sun Aug 20, 2006 9:43 am
Yeah, i think it was on 65? It said it was bone dry but i needed setup for moist? maybe it was a little slippery
PostPosted: Sun Aug 20, 2006 11:04 am
whinja ninja
whinja ninja
nah practice was bone dry, quali is moist.
I don't know my name anymore.
PostPosted: Sun Aug 20, 2006 11:51 am
Is 65 too high then? Its probably one of those unlucky things...
PostPosted: Sun Aug 20, 2006 1:48 pm
Slow-Po
No, I would guess that it was just bad luck combined with your setup being way out.
When you start setting up the car;
1) check whether your team mate is doing practice or has completed practice.
2) Once they have completed, hopefully they would have loaded up their set up values. Copy and paste this into notepad.
3) Go to car setup. If you team mate has already completed practice, load up their settings, check this against the values you have copied into notepad (sometimes they may have already changed their setup for the wet).
4) If you are the first one from your team to complete practice, go to "engineer's advice" and take note of what he is recommending. Then go back and put your settings to 50 if the advice is "medium", 75 if "high", or 25 if "low".
5) Then make sure you have the right risk level (65 is ok to start off with, increase it for the last few laps with the last one run at 100), and the right tyres, and then click on "Test".
6) After every lap, scroll down and see what the recommendations are (higher or lower). Then you have to methodically change your values (don't go making changes greater than 10 between laps) in order to narrow down to the right value.
7) Once you have completed your laps, be a good team mate and share the data with your team mate via "Team Talk" like the following;
Here is the setup after practice
Wings
60-100
56
Suspension
43-45
55-58
Anti-Roll Bar
83
60-70
Ride Height
55-60
52-55
Tyre Pressures
45-50
60-70
Gears
55-60
Brake Bias
40
Anybody else want to add anything I may have missed? 8)
PostPosted: Sun Aug 20, 2006 8:57 pm
Yair.
That Dr Escudero fella is a right wally.
Watch out for him :wink:
PostPosted: Mon Aug 21, 2006 7:41 am
Slow-Po
awdmoke wrote:
Yair.
Gotcha. Unfortunately, it appears that this is the view of him that most of us are getting. :wink:
PostPosted: Mon Aug 21, 2006 1:22 pm
resident alien
resident alien
You wish! There's no way you'll be in front of me for me to see that view. In another 96 minutes the only view you'll see is team McLaren leaving you all for dead!
PostPosted: Mon Aug 21, 2006 4:52 pm
whinja ninja
whinja ninja
Marvin you bastard! you cursed us!
PostPosted: Tue Aug 22, 2006 8:16 pm
resident alien
resident alien
:oops: :cry: :oops:
PostPosted: Wed Aug 23, 2006 4:11 pm
Slow-Po
Hey Marvin! :lol:
PostPosted: Wed Aug 23, 2006 6:05 pm
resident alien
resident alien
Consider yourself lucky buddy! I may put in a protest... I thought I saw pooboy (aka Dr Crash) in my pits during my pit stop... he MUST have done something to my engine to make me pit an extra time :evil:
PostPosted: Wed Aug 23, 2006 6:41 pm
Slow-Po
Buy it.
PostPosted: Wed Aug 23, 2006 6:49 pm
resident alien
resident alien
Hmmmm.... fine no more excuses! You're going down Dr. Death!
Users browsing this forum: No registered users and 284 guests
