It is currently Fri Jul 18, 2025 12:54 pm
Post new topic Reply to topic  [ 148 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
PostPosted: Thu Aug 24, 2006 8:36 pm
SWEEEEEEET
PostPosted: Tue Aug 29, 2006 10:31 pm
what are Side repeaters?
Baracade
PostPosted: Tue Aug 29, 2006 10:50 pm
Indicators that are on the front guards.
PostPosted: Wed Aug 30, 2006 9:22 am
That paint scheme looks like my mini !!! :twisted:
Roundies Rule !!!
PostPosted: Wed Aug 30, 2006 10:51 am
and ten thousand other minis
PostPosted: Mon Nov 13, 2006 6:51 pm
has anyone had prolems with front end my castled nuts just keep striping and my front brakes are not working new cylinder no leaks ?
PostPosted: Mon Nov 13, 2006 7:41 pm
Mate
What CVs are you using, if the nuts are stripping it will allow the discs to move causing pad knock off big time, when you bleed the brakes do you have a good pedal and then loose it after a drive, check the bearings in the hub and make sure it is not collapsing, what tension are you pulling the castelated nut up to, some of the sports sedans have broken the CVs but they usually break the drive shafts untill they use special ones of those
Wish I was close enough to pop around but PM me if I can help
Jon
PostPosted: Tue Nov 14, 2006 6:08 pm
the castle nuts i think need a spacer the brakes do not go hard i was thinking that also due to the angle on the loose disc
PostPosted: Tue Nov 14, 2006 8:41 pm
You should have a tapered washer between the nut...
PostPosted: Sun Nov 19, 2006 11:00 am
got that does any one what to tourqe it up to
PostPosted: Sun Nov 19, 2006 11:51 am
without seeing what you have done, and what brakes you are using (I assume Metro's)
it's a bit hard to speculate. However if your cars been runnin on loose bearings it's time to buy a set of timken Taper bearings for your front's and upgrade the old ones.
check the font pads for unevenwear, and the disc's for out of round, replace as nessacary, don't risk dodgy brakes.
inspect calipers for bends or cracks, same goes for them.
when the new taper bearings are in and greased up, put that funny looking tapered washer in and then the castleated nut, tourque it down slowly, rotating the disk as you go to keep the bearing all square to 200-270Nm (150-200 lbf ft)
I would set my torque wrench to 230Nm this compensates for any imperfections
and a few conversions:
13B Extend in a 1600
PostPosted: Tue Nov 21, 2006 11:47 pm
How did you go?
Baracade
PostPosted: Thu Nov 23, 2006 1:40 pm
where can you get that spray tint stuff from?
and can you see the lights working thru the tint? with norm globes
monkey
'75 windowless van
~LOLA~
PostPosted: Fri Nov 24, 2006 9:42 am
Die Die Die!!
willy wrote:
Amazing.
Love it.
Talk to Steve @ Brickworx Racing if you'd like side repeaters (clear or amber) to finish off the Sportspack flares.
08 8297 9494
the side repeaters are also available in ice blue...
PostPosted: Fri Nov 24, 2006 11:39 am
monkey
i think u can get that stuff from autobahn or smillar stores 8)
