It is currently Fri Jul 18, 2025 11:56 am
Post new topic Reply to topic  [ 342 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 23  Next
PostPosted: Tue Aug 29, 2006 11:29 pm
this is a great thread, loving the build so far 8)
PostPosted: Wed Aug 30, 2006 2:35 pm
looking vwery good chong!!
just a qstn why didnt you take the block and head to redi strip to get dipped?
PostPosted: Wed Aug 30, 2006 5:53 pm
Answer: To stay under budget! :oops:
Litterally, Redistrip would have made a $200 dent to the budget. I am in no rush and what I do have for free is good old elbow grease and passion.
Honestly the block and head is in pretty good condition. The paint that you see on there is set hard as I've already gone over the whole block outside with a wire brush attachment on a drill. Nothing a coat of POR15 or VHT won't fix.
The block will get a good going over before assembly anyway with cotton balls, cloths earbuds, air compressor... I think that's enough to get it clean.
Yes if you have an extra $200 to spare, redistrip the lot, by all means. I would rather spend that on go faster bits :P
Lillee - 1969 Morris Mini K
PostPosted: Wed Aug 30, 2006 9:01 pm
I f you have a sports shop nearby, grab a Rifle Brush set...(Or cleaning set)
Just right for getting into the main oil gallery and other nasty little nooks and crannies :D
a SINGLE piece of swarf missed in this area can wipe out a newly ground crank and all the bearings... can also take out the oil pump :shock:
so clean it again and again, and once more just to make sure... then get someone else to do it, until white cloths come out white.....
Good luck, I'll be watching this one :D
J
PostPosted: Wed Aug 30, 2006 9:07 pm
Thanks for the tip James! Didn't think about using a real brush rather than just cloth :lol: Hmmm I wonder if I can score a kit from Ebay :wink:
PostPosted: Wed Aug 30, 2006 9:17 pm
If you are not careful, typing the word "Rifle" into ebay set off just about every Project Carnivore 'bot on the 'net :lol:
The Cleaning kit i got had a little slot in the end so i could use strips of cloth.....much better at cleaning the barre....... umm the oil galleries :oops:
Good luck
J
PostPosted: Wed Aug 30, 2006 9:54 pm
Gotcha. Hey Ebay has some! what calibre should I buy? :lol:
PostPosted: Wed Aug 30, 2006 11:05 pm
ohhh good ol budget :x
that would be why... Redistrip have really gotten xpensive from Elmos rebuild to this one i was socked!
PostPosted: Thu Aug 31, 2006 8:21 am
Hay Kaz..thats a briliant idea... 8)
PostPosted: Thu Aug 31, 2006 8:34 am
Hey Chong,
good luck mate, i know you will do a great job as you are a very meticulous person.
should be a real smooth and balanced powerfull engine i am sure.
and as James B said clean it and clean it again and clean it again, also use a new oil cooler as they do hold allot of old crud in them too so if you have an old one throw it away and then pick it up again and throw it further.
Grant
100% Pure A Series Turbo
PostPosted: Thu Aug 31, 2006 8:57 am
Grant! Hey thanks mate! that means alot to me coming from you :D
Yeah I have a brand newie that I picked up 2 years ago at a swap meet for $25 8) I actually don't plan to run one... not at least until the engine is run in. If I do run one I need to change the front grille verticle brace to a 45 degree brace so I have not decided yet what I am going to do :oops:
PostPosted: Thu Aug 31, 2006 11:24 am
hey grant, completely off topic. are they stock mk 2 s flares on ur sig pic on ur car>??
sorry to hijack ur thread chong. i promise i will do so no more!
PostPosted: Thu Aug 31, 2006 12:02 pm
Hi Chris,
no, I used to have the STd MKII flares on it before the last paint job but these are the wider ones, i think they are copies of the competition ones from BMC in the 60's.
i'll email you some pics of these ones and the old one for comparrison
Grant
PostPosted: Thu Aug 31, 2006 12:10 pm
Bad Boy Chris! :evil:
:P
PostPosted: Thu Aug 31, 2006 12:31 pm
Sorrrreeee Chong :oops:
(thanks Grant :D ) woops there i go again :oops:
Soree again chong :oops:
