It is currently Wed Jul 02, 2025 3:18 pm
PostPosted: Wed Aug 30, 2006 3:37 pm
On the tag it says 70061 / 3585, I am confused as REVS doesnt accept a " / " in the VIN # field.
Roundies Rule !!!
PostPosted: Wed Aug 30, 2006 3:41 pm
WHat year is the mini ? Is one half of the number the same as the body number ? Have a look at a similar post in here from someone saying they can't find their car for ideas ...
PostPosted: Wed Aug 30, 2006 3:52 pm
Are you trying to check the Vin on a Mini 850?
PostPosted: Wed Aug 30, 2006 3:53 pm
Yes, its a 62 850
Roundies Rule !!!
PostPosted: Wed Aug 30, 2006 4:01 pm
second half is the body number , that's the one to use , first is a BMC number , to be ignored mostly .
EDIT , wrote them the wrong way around .....2nd number (in your case after the /) should be the body number ....
Thanks
Roundies Rule !!!
PostPosted: Wed Aug 30, 2006 4:05 pm
And a very early 62 850 I'd say from the body number , care to PM the rest of the details off the ID plate to me to put in the 850 register ?
PostPosted: Wed Aug 30, 2006 4:20 pm
Heres a pic of the Tag.
Roundies Rule !!!
PostPosted: Wed Aug 30, 2006 4:25 pm
COLOUR - Chartreuse
:lol:
Bah ha ha...first time I ever got pissed was on a bottle of something called Green Chartreuse
I haven't heard that word probably since that day!
Classic! :D
Thank's , I'll put it's details in a bit later and update the list to see where it comes . Interesting the plates been replaced for some reason (also explains the / stamped between the numbers ) , the original plate was stamped from the back and had raised numbers , this ones stamped from the front giving recessed numbers . Not illegal to do as it isn't a compliance plate as such but an ID plate from the manufacturer , normally done if the original was lost or damaged .
PostPosted: Wed Aug 30, 2006 4:31 pm
It looks like it was restamped a long time ago! :wink:
Just remember, it is an ID plate, not a VIN plate.
PostPosted: Wed Aug 30, 2006 4:35 pm
And after having a better look at the number it seems it was built mid to late 61 , still a bit of a grey area in the register there but it's the 3rd oldest ....
PostPosted: Wed Aug 30, 2006 4:52 pm
So is it the ID number that you provide to REVS for checking up on?
Roundies Rule !!!
PostPosted: Wed Aug 30, 2006 4:55 pm
Usually the number stamped on the body was used as the chassis number. The number on the ID plate was just ignored by the rego authorities.
PostPosted: Wed Aug 30, 2006 4:59 pm
What morris1100 said , normally it's the body number which will also be the second half of the number on the plate on the earlier 850's (with English motors like yours) , occasionally though they'll be recorded as the full number with a space in between but I've only seen a few like that , they've been re-registerred after sitting somewhere for many years and the peopl doing it didn't understand the numbers .
