It is currently Sat Jul 19, 2025 3:22 am
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Aug 26, 2006 9:24 pm
Hi Matt,
FMIC progress as promised. Still a long way to go though, and lots of reconfiguring of the front spoiler. But its a start. To be mounted still are the 100mm VY Commodore fog lights, indicators and cold air intake.
Top bracket:
Bottom bracket:
Bottom bracket mounting to IC:
With front spoiler:
And again head on:
Like I said, still lots more work to do to modify the front spoiler and get it ready for painting. BTW - Zeemax quality is absolutely crap!!!
Regards,
Tricky
PostPosted: Mon Aug 28, 2006 2:57 pm
Hey Matt,
How's the plumbing coming along? :lol:
Just wondering if you plan on MIG welding all the header pipes? Does the steam pipe your using weld well? or would it be better just to tack (strongly) everything together and then get it TIG welded by someone else?
cheers,
Pierre
PostPosted: Tue Aug 29, 2006 2:15 am
Hi Pierre, Below is a pic of my progress. It is coming along well. The technical term for the bends are buttweld elbows (aka plumbers bends). They are approximately 4mm thick which is perfect as it is quite thick which means I can wind the Mig up and do nice welds. The pipe I am using has similar wall thickness. I should have the whole thing finished off tomorrow. So I wil through up a final pic when it is finished.
Matt
PostPosted: Tue Aug 29, 2006 11:23 pm
Well guys got very close to finishing today before my Mig gave up the ghost again...Anyway here's a pic and I promise to not to put another pic until it is finished...
 Post subject: headers
PostPosted: Wed Aug 30, 2006 7:27 am
looking extremely good.
PostPosted: Wed Aug 30, 2006 8:45 am
wow looking great matt, looks like a pretty god flowing design, dont know to much about the turbo you have, any specs on it?
1974 Moke - 998cc
PostPosted: Wed Aug 30, 2006 11:23 pm
dayum looks good!!
hows the room with the bodykit around the fmic? i'm looking at going along the same route with that kit....
PostPosted: Thu Aug 31, 2006 8:13 am
Matt,
Sorry to hijack your thread!
Idearat,
Clearance was barely minimal for the FMIC with the bodykit on.
I had to cutaway a fair amount to get it to sit right back.
Its a 3-inch IC, so fairly deep but it is as far back as it can go, tilted back at the bottom about 8 degrees.
Some alteration of the bodykit will be happening to accomodate the driving/fog lights and cold air intake for the air-box. The pipes will be routed through the old indicator/parking light apertures. There isnt much room there. All piping will be 2 1/2 inch, or 64mm and most of it will be alloy (some bends to be fabricated to allow for the tortureous route).
I hope this helps. I will host some more pics (own thread this time - sorry Matt) after I have done the fibreglassing.
Andy
PostPosted: Thu Aug 31, 2006 2:01 pm
Brad yeah not sure similar to a tD04 I believe. I think it is a suck it and see. Either way a huge improvement over the CT9. Fixed the MIG last night so I should have the manifold completed this weekend and turbo bolted up (will post pic). All 32mm ID runners and yeah should flow a heap better than the current jobbie (still that's a pretty sure bet). And yeah Andy feel free to start your own thread...
Matt
PostPosted: Thu Aug 31, 2006 4:00 pm
Looking good Matt, I've got a bag of fittings that ended up not being able to use because i had no room. I would have liked to have built mine the same way as you have, perhaps the next one.
Looking foward to seeing it in October.
Dan
PostPosted: Thu Aug 31, 2006 8:23 pm
Yeah Dan the luxury of the Clubby extra 50mm (or so). Oh well out to the shed to finish her off...
Matt
PostPosted: Thu Aug 31, 2006 11:44 pm
Well guys pretty much finished the manifold. Just got to finish off the seams but overall pretty much done. Dropped the new turbo in to see if it fit (always a good thing after the amount of effort), and as you can see a pretty neat fit. And what's more the other radiator kindly supplied by Craig from NZ fits a treat so it looks like I might have her on the road by end of Sept...
PostPosted: Sat Sep 02, 2006 9:22 am
Hells Bells Matt, that looks great!!
I can see the added horspepower from here.
Will you Dyno it for us to see the power difference you have created??
Good stuff (you never cease to amaze me with your engenuity!!)
Regards,
Andy
PostPosted: Sat Sep 02, 2006 9:45 pm
Thanks Andy, yeah I will definitely dyno it and put up the sheet. Basically I was running almost exactly 70kw based on shootout mode at Jake's Performance. So I will take it back there that way I don't have the issue of different dynos and we will see what happens. Should have the intercooler by end of this week hopefully so we will see what the go is then. On the road by end of Sept I think?
PostPosted: Sat Sep 02, 2006 10:04 pm
Resident Haemorrhoid
looks great Matt,
Slightly off topic
what brand of wire are you using on your mig and is it a gasless mig the stuff i got with the Mig is Shite
trying to workout the best brand to buy so i get a better result.
Gadget
mtsmini wrote:
Users browsing this forum: No registered users and 28 guests
