It is currently Fri Aug 08, 2025 9:24 am
PostPosted: Wed Sep 06, 2006 2:15 pm
Whats the secret to removing the knuckle from the end of the trumpet? TNT?
PostPosted: Wed Sep 06, 2006 2:30 pm
i didn't even know you played an instrument... :)
PostPosted: Wed Sep 06, 2006 2:33 pm
How to remove my knuckle from a strumpet?
PostPosted: Wed Sep 06, 2006 2:53 pm
Smash the bejesus out of it until it budges...took me 3 days with heat, oil, dipping, a vice, lots of patience and a sh&tload of swearing(seems to be a regular thing in my garage at the moment!!!)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Sep 06, 2006 3:26 pm
CPOCSM sounds familiar, have you served on Sheean? Were you on O boats??
 Post subject: Trumpet
PostPosted: Wed Sep 06, 2006 4:38 pm
Oxy,
Heat up the alloy (should only will need to be warm) all the way around, nuckle in the vice and then kinda unscrew the nuckle from the trumpet...real easy!
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
 Post subject: Re: Trumpet
PostPosted: Wed Sep 06, 2006 4:46 pm
My_Mini_Rocks wrote:
Oxy,
I'll give that whirl Thanks
PostPosted: Wed Sep 06, 2006 4:49 pm
Set the trumpet up knuckle end down.
Pour in lots of WD40 (or pentrating fluid of choice).
Wait.
Place long drift (get one whose diameter is less than that of the pin on the knuckle joint) down centre of trumpet - make sure the drift rests on the end of the knucle and not the inside of the trumpet.
Suspend trumpet in vice using top flange (pad vice with bits of wood).
Bang on drift with hammer.
Cheers, Ian
PostPosted: Wed Sep 06, 2006 5:27 pm
Nah - Skimmer all the way(originally an RP then a CSO)
FFG's and FFH's - now ar D-scum!!
Oooooo - speaking of Hi Los - got my rip speed ones finally - wasnt Minisports problem but the defence mail system - bunch of numptys!!! Box all crushed and wet - at least the Hi Los are metal and not damaged!!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Sep 06, 2006 5:39 pm
Wait.
Cheers, Ian
It might hurt less than the oxy (I still have the scar - but no feeling from the last time I used on oxy)
PostPosted: Wed Sep 06, 2006 6:01 pm
D-scum hey. Interesting job???
don't get me started on the defence mail system or lack there of!! :evil:
PostPosted: Fri Sep 08, 2006 1:10 am
Wait.
Cheers, Ian
Thats exactly how I do it. Works every time. Most of the time I dont even use WD40 or anything like that.
Unlike the way My_Mini_Rocks does it, you wont damage the knuckle by doing it this way, which is handy if the knuckle is salvageable :wink:
PostPosted: Fri Sep 08, 2006 8:42 am
for $13 bucks retail...who cares bout the knuckle....lol
normally if they are frozen in the trumpet, they have been in there for a while anyhow and show signs of wear...
:D
Ph: 08-8177-1275
Skype: minisport.au
PostPosted: Fri Sep 08, 2006 9:51 am
One of my old trumpest has a lot of what looks like really bad bubbling aroung the edge where the knuckle fits in. Looks like a heat caused thing - wikll get some pics for you. I dont think it would be safe to use it again and in fact I think it could collapse...
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Sep 08, 2006 11:01 am
"Should only need to be warm",
Its alloy.....not to hot or you will easily distort it
What ever works for you all.... :lol:
How do you think they get the metal in a mould!....heat it up and shape it....
Ph: 08-8177-1275
Skype: minisport.au
