It is currently Wed Jul 23, 2025 12:41 pm
PostPosted: Mon Sep 11, 2006 1:29 pm
I am looking for referrals; I need to get a dry sub frame sand blasted in about a week or so. I am the ACT / Canberra / Queanbeyan area. Has anyone out there previously had one done here using local services down here? If not, I could always go up to Sydney if you know of someone up there that can do a good job with clean grit.
PostPosted: Mon Sep 11, 2006 5:49 pm
Slow-Po
If you are thinking of coming to Sydney, do a search on "soda" :wink:
PostPosted: Mon Sep 11, 2006 6:52 pm
For a subframe I would go with a sandblaster as it is not going to be damaged by harsh abrasives.
For a body or panels I would go with soda. :wink:
There is a bloke in Goulburn that does blasting. :wink:
PostPosted: Mon Sep 11, 2006 7:27 pm
Nope Sand blasting can and does with some operators stuff your Pannels.I would also look for a local Soda Blaster
PostPosted: Mon Sep 11, 2006 7:30 pm
there's a guy on here "mini mike" who's doing a bootlid for me right now, he lives in sydney, send him a pm
PostPosted: Mon Sep 11, 2006 7:35 pm
He is not doing panels, he is doing a subframe. :wink: You could knock the paint off with an axe and not stuff it. 8)
PostPosted: Mon Sep 11, 2006 7:36 pm
ON TOPIC: Go and buy The Mini Experience this month (out this week) and read my RESTORATION article. All you need to know about SODABLASTING will be revealed :wink:
PostPosted: Mon Sep 11, 2006 7:38 pm
R Yes Opps :wink:
PostPosted: Mon Sep 11, 2006 9:03 pm
Huggy...there is a grotty little place in Fyshwick that does good work. If you are coming form the airport along the new Dairy Flat road through all the Canturf farms you can just see the big shed on the left as you head towards Fyshwick.
Turn off Newcastle into Gladstone and about opposite Maryborough is open land....follow the dirt track about a couple of clicks down past the metal wreckers etc until you come to the Grit/Sand Blasters.
PostPosted: Mon Sep 11, 2006 9:46 pm
Charges $80 an hour but if you have a heap of stuff to do - he will probably get it all done in an hour. A subframe will probably take 60-90 mins so throw some suspension bits in too(this was his advice to me - makes it worth your while).
Hooroo
Rob Forsyth
Miniot!!
Users browsing this forum: 1071 S and 82 guests
